Old 8th September 2012, 04:44 AM   #1
nonsuchpro's Avatar
Question Driver reccomendations for a new full-range build.
Hey all.
I'm looking to build entry-mid level full-range bass-reflex speakers using 6 1/2" or 8" drivers. I'm looking to spend no more than $400-500 for the pair. My choices so far have been the Audio Nirvana super series cast 6 or 8, Tang Band W8 1808/1772, Dayton PS220/180 and the Fostex FE206En. I'm sure there's others out there as well which I would love some recommendations if better than the ones I listed in my price range.
One question,
I am augmenting the low end with a sub, would 6 1/2" be a better choice for clarity and possibly louder highs? It is crucial that the drivers produce a strong signal to at least 16k+. I realize they all say they will do 20k.
Thanks in advance!
My Studio
Old 8th September 2012, 05:26 AM   #2
Banned
If you chose Audio Nirvana then I would definitely go with the 8" instead of 6.5", however the other drivers I can't comment as every speaker is different.
Old 8th September 2012, 09:26 AM   #3
zman01 is offline zman01  Bangladesh
Fostex FE206en works better in a horn - it is not very suitable for BR.
You might consider the Mark Audio Alpair 12P - couple of limks from the MA forum:
Alpair 12P Gen. 2 (paper cone)
Alpair12P gen2 standmount speakers
I have a pair, but haven't started to break in yet - so would not be able to comment on the sound. Initial feedback is favorable though.
Old 8th September 2012, 12:57 PM   #4
fakeout is offline fakeout  Canada
fakeout's Avatar
I don't even understand what's going on here. If you're going to use a subwoofer, why wouldn't you use 3" full range drivers instead?
(Actually, from what I read, I'd prefer woofer/tweeter but that's another topic. Besides, I read stereo woofers > single sub.)
Feeling Good by David Burns
Old 8th September 2012, 03:40 PM   #5
Alpair 7 is a good choice with really good highs and mids.
Old 8th September 2012, 05:22 PM   #6
2nd that. If you go for the 8" TangBand consider relieving the top-end with a tweeter.
If you're going to use a sub consider the 3" W3-1878 which can be crossed quite low (60-80 depending on desired SPL). There are many good 3" FRs that will integrate nicely with a sub.
3s are generally less beamy than 4 or 5 inchers but they go deep enough in the right enclosure to be sub-friendly. In addition they often sound sweet all the way up.
3 + Sub or 8 (or bigger) + tweeter is what I'd build. 8+Sub doesn't quite make sense. Check out Bob Brines' enclosures if you are looking for a good all-round speaker based on the 8in premium TBs (1772 / 1808)
Old 8th September 2012, 05:31 PM   #7
+1 for castlesteve's suggestion on Alp 7 - as he has stated, the mid-range is really good, top is also well extended with very good dispersion. The separation of different instruments and the imaging is also top notch.
fakeout,
It's not that difficult to understand. How low would you cross a 3" driver? The OP has stated that he would like to augment the low end with a subwoofer, not helper woofers. So how high would you cross a sub? So, when we are talking about higher dynamic range an SPLs and crossing with a sub (80-110 Hz maybe), then a bigger driver like the Alp 10.2 or 12 can be considered. IIRC Bob Brines has experimented with the Alp 7.3 crossed at 110-120 Hz with bass helpers and it's worked out really well. What I have read from P10's experience and experiments, most of the 3" FR units were XO'ed around 300-333 Hz - a sub will not go that high up.
But agree, probably 6.5" is not entirely necessary here since we talking bass helper. And +1 to your suggestion on stereo subs.
Edit: Nakamoomin - I am not sure if a 3" will perform well at higher (90 dB SPLs) going down low as 60 Hz - especially in a smaller cab. What type of music are you considering? Can you share the details on the diver you are referring to?
Lot of the 4" drivers aren't beamy (MA Alp 7, CHR-70.2, CSS EL-70), yet offer good dispersion.
Old 8th September 2012, 06:11 PM   #8
The 3in from TB has an Xmax of 5mm. That's 10mm of linear stroke.. Couple that with a 10 liter or so BR tuned to 50 something Hz and you'll probably get all you need if you can relieve with a sub @ 75-100Hz.
There are some really nice 4 and even 5 inchers out there, you're absolutely right. But generally 4s and up are more beamy than 3s. I'm sure either of your suggestions would work nicely in a BR or TL with a Sub.
Old 8th September 2012, 07:46 PM   #9
frugal-phile(tm)
planet10's Avatar
Hard to beat the Alpair 7.3 in this application. If you want to play louder, you can still end up with something very good with the Alpair 10.2 (if does give up some finesse to the A7, but unless you listen to one after the other wouldn't know).
I can't speak to the Audio Nirvanas, i have yet to hear any of the cast basket ones, the stamped ones i have heard are underwhelming.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th September 2012, 02:42 AM   #10
LineSource's Avatar
If there is only one shared subwoofer, then the TB W8-1808 in a 4cuft MLTL tuned to 35-40Hz would be a good choice. A quick search will yield many positive comments for the W8-1808. Several well reviewed JAES papers proved that a listener can physically locate bass sources when much above 60Hz. We have the TB W8-1808 MLTL in our bedroom and are very satisfied with low-mid-high coherence. The treble is smooth to 12Khz, but has whizzer roll-a-coaster SPLs above this. We find that no baffle step compensation is necessary if the speaker is against the back wall.
If there are separate stereo woofers, then consider building a 3-way with a wide bandwidth midrange/fullrange with a Xover from the woofer ~120Hz, and a Xover ~6Khz to a 0.5" - 0.75"(Seas 19TFF1) dome tweeter. This arrangement can provide 20Hz-20KHz with single cone coherence over critical midrange, Doppler IMD below 40db, and smooth control directivity of high freqs to over 20Khz.
First time Full Range Build tshaq Full Range 5 10th March 2012 06:00 PM
Ok, so I want to build my first open-baffle full-range uncle_leon Full Range 75 2nd September 2011 09:04 PM
No-Name full range Driver ArjenShenzhen Full Range 13 18th August 2008 12:19 PM
Full range PS cabs? Anyone build any?? Zero Cool Multi-Way 6 27th March 2007 03:19 PM
My first potential full range project (reccomendations?) fazman Full Range 4 1st August 2006 10:12 PM
Copyright ©1999-2013 diyAudio
