fostex ff165wk in voigt pipe
Old 7th September 2012, 12:15 PM   #1
leo2 is offline leo2  Netherlands
Default fostex ff165wk in voigt pipe
Hello!
After building Half Chang speakers with Fostex FE206 en, I am looking for a
new project.
The Half Chang's do sound great but they miss a bit of low end considering the size of them.
I am thinking about something a bit smaller and the Fostex FF165wk looks
interesting to me.
Would they fit a (folded) Voigt pipe? Or would it be possible to re-design the
frugel-horn to fit the FF165wk?
I use a 10W single ended tube amp.
Room size is about 18,5 m2 and 52 m3.
leo
Old 7th September 2012, 12:59 PM   #2
GM is offline GM  United States
GM's Avatar
T.C.'s original BIB if the height is acceptable and backed up against a wall and preferably in corners is an option.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 7th September 2012, 01:23 PM   #3
family won't aprove with a BIB, and there's no usable corners
Old 7th September 2012, 02:51 PM   #4
zman01 is offline zman01  Bangladesh
leo2, how many hours have you got on the drivers?
Old 7th September 2012, 04:09 PM   #5
chrisb is offline chrisb
Perhaps part of your disappointment from the FE206E in Chang is that they were originally targeted for FE207E - the appropriate enclosure of that catalog's vintage for the 206 would have been Sachiko "Olson Manifold Horn" - granted a much more detailed build and larger cabinet.
To answer the question re modifying FH3 - in short, an experienced dental surgeon might be able to stuff this 6" driver in the enclosure, but not without severely hamstringing the performance - and I doubt you want to be underwhelmed by this next build.
Terry Cain's original Abby (now Lovecraft Designs) was optionally outfitted with the earlier FF165K (in fact a buddy of mine had both 165s and 167s for his) - presumably the WK would work well enough in a similarly dimensioned "classic" Voigt pipe.
More likely is that something like a floorstanding MLTL such as Brine's M12-FF165, or a "pensilesque" would likely deliver the implied desirable compromise of bass weight/extension, relatively simple build and domestically acceptable form factor. But, to echo GM, to squeeze the most juice from the bottom octaves with this class of drivers - bigger is (probably) better - and there are several such designs from which to choose.
kinda burnt out - taking a break
Old 7th September 2012, 07:30 PM   #6
Chrisb, I'm not disappointed with the Chang. I actually love them except from the bottom end. I don't want real heavy bass, just a little bit more, but (if possible) with a smaller
footprint.
What I meant about re-modifying FH3 is to somehow upscale the concept of FH3 to fit
a 6" driver. I don't know if this is possible and I don't know how to do it, but somehow
it seems like an interesting option to me.
leo
Old 7th September 2012, 07:45 PM   #7
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
a 6" driver.
That same question has been asked so MANY times. We tried from the start with no success. 4-5" is the sweet spot it seems
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th September 2012, 08:04 PM   #8
Dave,
So to try the FF125wk would be a better option?
Is there an answer to why it couldn't be done with a 6" driver?
(I'm trying to learn)
leo
Old 7th September 2012, 09:11 PM   #9
Dave,
For the FH3? yes - certainly a better option than attempting to shoe-horn any 6" driver in that enclosure.
As your room is of moderate dimensions, this size of driver could well be a sweeter choice overall.
Keep in mind that of the Fostex drivers, one that was on the original short list of candidates for the FH3 was the FE126En - although the FE108EZ and perhaps even FX120 & F120A could work. One that we know for sure doesn't "sound favorite" (to use a Woden-ism), and at frequency range well above the bandwidth at which the rear horn load is of benefit, is the FE138ESR
leo
Scott might be willing to address that question again, or perhaps Dave could delve in the archives for earlier replies and post as a sticky here, or on the FH site?
Last edited by chrisb; 7th September 2012 at 09:16 PM. Reason: furtherance of detail
Old 7th September 2012, 10:38 PM   #10
frugal-phile(tm)
planet10's Avatar
Anything that works gets so big you might as well build A166 or Victor (for FE166).
dave
fostex ff165wk in voigt pipeHide this!Advertise here!
Fostex FF165WK in ported box nightuser Full Range 4 20th October 2011 07:39 PM
Voigt pipe as a TQWT Keriwena Multi-Way 5 21st June 2010 10:17 AM
Voigt Pipe is looking for new home mkapszewicz Full Range 9 21st December 2009 02:17 PM
Folded Voigt Pipe Ropie Full Range 18 2nd November 2005 03:31 PM
MTM on a Voigt Pipe ? johninCR Full Range 2 8th April 2005 06:20 AM
