full range in an existing small cabinet
Old 10th September 2012, 03:13 AM   #31
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
You do need to make as close a calculation as possible to determine your available volume. Perhaps you could fill the sphere with some sort of dry media, Freeze died peas, wood shavings or..??? Craft a box at 100mm by 100mm, with an open top & see how high up it gets..??? A flat circular baffle covering the "opening"....If ported, I would opt for a port pointing down, slightly off from 90 degrees. And yes you need to get it sealed as best possible, any leakage variations will throw off your calculations.
Just throwing out some ideas here.
__________________________________________________ _Rick.......
Last edited by Richard Ellis; 10th September 2012 at 03:15 AM. Reason: additional thoughts
Old 10th September 2012, 02:23 PM   #32
mda1 is offline mda1  Netherlands
To do the volume measurement I used water. And i repeated it 4 times and took the average value. So I am quite certain about the 3.3 liters (without driver or BR port). My error should be less than 0.1 l. After all, i'm a physicist working at a company whose motto is 'measurement systems'...
The seal is already provided by the enclosure used, as long as I cut my baffle out in the right size.
I think I'll start with a sealed enclosure, then vent it a bit by putting washers underneath the screws of the driver (0.5mm or so), and then port the baffles. this way with one piece of woodwork I can try several things proposed here. Once I'm happy, I'll leave it as is.
Old 11th September 2012, 05:13 PM   #33
Ok. The fostex are ordered. I bought some MDF and some pipe with and inner diameter of 25mm.
In the meantime reading up more on speaker building, and of course more question arise. For example: should I chamfer the inside of the baffle where I will mount the driver?
And the speakers were stuffed with soft material when I took them apart. I was planning on putting the same stuffing back in. Is that a good choice?
And should I countersink the driver?
Old 11th September 2012, 05:41 PM   #34
chrisb is offline chrisb
IMO always an excellent idea on smaller fullrangers such as the 85s, you do need to be careful to retain enough material core for mounting screws ( I find #5 x 5/8 or even 1/2" is more than adequate for these little guys)
time will tell how much and type will give best results - I'd opt for less to start with
the mounting flange on these is thin enough and gently radiused that countersinking is likely far less critical than with say a Alpair6, but it can make for a tasty project - it will be a test of either your freehanding or pattern making skills
kinda burnt out - taking a break
full range in an existing small cabinetHide this!Advertise here!
Spherical Cabinet vs. ordinary Cuboid Cabinet for full range Speakers tiefbassuebertr Full Range 1 10th January 2012 04:49 PM
Easiest cabinet design for full range driver terpkev Construction Tips 23 31st July 2011 08:16 PM
Novice questions re: 1st DIY full range project - existing cabinets rbclark Full Range 23 24th August 2007 01:59 AM
Full range and/or High Efficiency possible in small cabinet? Seraph Full Range 29 19th June 2007 01:13 AM
Help selecting a small Full Range mimir Full Range 9 31st August 2005 05:41 AM
Copyright ©1999-2017 diyAudio
