China made 4" fullrange advise wanted - diyAudio
Old 31st August 2012, 02:10 AM   #1
weiyan is offline weiyan  Hong Kong
Default China made 4" fullrange advise wanted
о* ֵQ4ձȫƵ HIFI-Ա
Sorry for the description is Chinese. You could look at the picture.
Power range: 60-100W
Frequency: 55Hz-25KHz
Impedance: 4 Ohm
Sensitivity: 89db/W
Dimension: W(158mm)*H(265mm)*D(245mm)
Weight: Around 12KG/pair
Really deep base not need, for I believe better pair with sub woofer if I want the deep low base.
I concern the performance above 80hz, may be 100HZ + .
Thanks for advice.
Old 31st August 2012, 02:19 AM   #2
GM is online now GM  United States
GM's Avatar
I am not sure what type of advice you want, but with no T/S specs we can not help with a box design unless some one here has experience with this driver.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 31st August 2012, 02:36 AM   #3
I may buy one. My concern is the bass is so powerful as the users comments said. I am comparing with a peerless 5" two way speaker.
I think the sense of "full powerful bass" is usually come from 70-115Hz. So I concern this frequency.
Another concern is I am using a class B amp with regulated power supply. The psu impedance may too high for 4 Ohm speaker.
I am sorry don't have spec. of the speaker. Hopefully there may some user has experience with this speaker.
Old 31st August 2012, 03:01 AM   #4
GM's Avatar
If you say so. I didn't try to Google translate the page. The response plot shows a high Q peak around 110 Hz, but do not know if it is because it has a high Q motor or it was measured in a too small box.
Maybe best to just make/use a sealed box as shown and XO it to a 'sub' system around 70-80 Hz. If the little box sounds too 'strong', then vent it to lower its tuning.
GM
Old 31st August 2012, 03:58 AM   #5
borispm is offline borispm  Hong Kong
borispm's Avatar
Send a message via MSN to borispm
Weiyan,
Here are a few easy tips:
If the midbass is too strong, you can try to position further away from the rear and side walls. I would put them on taller stands too.
You may also want to plug the port with a foam or rubber bung.
Try to use an amp that sounds "lean", say small T-amps, instead of "warm" sounding ones.
Hope that helps.
Boris
Old 31st August 2012, 06:18 PM   #6
tvrgeek is offline tvrgeek  United States
4 inch and "powerful" bass does not match. Lack of high frequencies that give it a bias to the lower hundreds does. IMHO, trying to fix a bad speaker with problems in the many percent range with differences in amps in the .00 something range is useless.
4 inch and 100 Hz is a reasonable target IF the driver was made to do that and IF the room is not too large and IF you don't play it too loud. I am not yet convinced a 4 inch driver is usefull at all above about 8000 unless augmented with a wizzer cone with all of its problems.
The specs above are wishful thinking on the manufactures part.
Old 31st August 2012, 06:20 PM   #7
Look at their frequency plot! Terrible!
Old 31st August 2012, 08:06 PM   #8
ODougbo is offline ODougbo  United States
I wouldn't go smaller than 5", if you are looking for some bass.
Peerless makes some really nice drivers (post #3) , why not go back to them?
Old 31st August 2012, 10:07 PM   #9
fakeout is offline fakeout  Canada
fakeout's Avatar
Uh, I have a pair of 4" Visaton R10SC full range drivers and when I cranked them up just to hear on a Lepai 2020A+ amp, I wasn't blown away by the bass regardless how low these go. Even if it wasn't in an ideal cabinet.
Feeling Good by David Burns
Old 1st September 2012, 02:14 PM   #10
Thank you for the advice. Its better to keep away from this speaker.
Krell S300i Integrated Amp "Made in China" which Factory? tiefbassuebertr Solid State 10 29th October 2011 09:17 AM
Need advise about China AMP lmaidson Class D 4 2nd July 2010 10:02 PM
Fullrange Drivers From China! thetubeguy1954 Full Range 44 25th December 2009 09:44 AM
Copyright 1999-2017 diyAudio
