#61 |
You did that with a "skill saw" good example what can be done if you put your mind to it
[compound angles are the worst to deal with] Again, nice job, design, wish I could hear them. Q. Does the tall angle boxes have baffles? What is the volume? |
#62 |
yes a skill saw no joke
. No baffles just the front wood glued to the both sides. The volume I don't knoe but, my next one will be done using the correct volume for the drivers. Hay if your near canton michigan stop over you can hear them any timeLast edited by natural sound; 3rd September 2012 at 06:59 PM. |
#63 |
Does not stay sticky. I also tried a 3M "scrapbook makers" glue and a 3D fabric paint. All of these produce something about half the density of a hot melt glue stick. Denser and stiffer than RTV.
#64 |
Okey I thought I read sticky sorry jm
#65 |
frugal-phile(tm)
The way zig dries is that it remains somewhat sticky if it dries in the presence of oxygen (provides adhesion similar to a post-it note., acts as glue if not (ie between 2 pieces of paper)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#66 |
Okey that makes sense. Thanks jm
#67 | |
Sometimes volume is hard to calculate with "crazy shapes"....can away use 2 litter bottle with sand or cardboard box with shipping peanuts.
E.g. fill a 12" x 12" X 12" (or whatever size you need) cardboard box with peanuts and just pour them in the speaker box, (semi finished). Even if math is a attribute, this is a final/double check. Quote:
#68 | |
The FF165WK would be a better driver without the peak. Also the FF85WK does not have the peak but its power is limited and so is the bass. The FF105WK may be an option. We have our home on the market and when there is an "open home" I have some background music. Already I have had several requests for building a pair unfortunately health is prohibiting that. I am presently tossing up building a pair for in my office (the FF125WK were destined to go into the office but my wife has taken possesion of them) with either the FE103En or the FF105WK. The FE103E(n) is a cult driver in Japan and does not ahve the peak but excursion is limited and so is bass. From what I can gather on the FF105WK is that the peak / dips change when listening off axis which leads me to believe that a metal grill will improve things. I certainly found that to be the case on the FF125WK (needed a grill in a hurry so ordered the Fostex grills - they'll fit but you'll need to remove the raised paper ring on the FF125WK). Those who scoff at the idea: the LS3/5A used a grill on the tweeter, not for protection but for improving the HF response. It is true that they look ugly. Last edited by AmadeusMozart; 15th September 2012 at 04:50 PM. |
#69 |
" The FF165WK would be a better driver without the peak. Also the FF85WK does not have the peak but its power is limited and so is the bass. The FF105WK may be an option."
Exactly what I found trying to make the 125 work. It just seems to be the problem child of the series. |
#70 |
De ye want to take a bet on that?
| ff125wk vs w4-1337sdf (ferite) | norman bates | Full Range | 59 | 1st August 2012 10:21 AM |
| FF125WK and Fonken | efreddi | Full Range | 5 | 13th March 2012 11:37 PM |
| Planet 10 FF125wk dFonken125T 0v8 | jonparkhurst | Full Range | 74 | 13th February 2012 05:15 PM |
| Taming harshness in horn tweeter | rongon | Multi-Way | 168 | 10th February 2012 11:55 PM |
| Speaker enclosure for FF125WK | vintvolt | Full Range | 14 | 12th December 2011 08:25 PM |
