taming harshness of fostex FF125WK
Old 19th September 2012, 09:35 AM   #131
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Naturally.
I still picture Sarah as Virginia in At Home with the Braithwaites -what was it one of the other characters called her? 'My chain-smoking, screwed up dyke of a sister.' Brilliant performance. And coming from an acting background, I don't say that lightly.
Old 19th September 2012, 07:19 PM   #132
tvrgeek is offline tvrgeek  United States
Too expensive for me. I mean Sarah. Plywood in not a problem if I can source local suppliers.
Old 19th September 2012, 08:11 PM   #133
ODougbo is offline ODougbo  United States
TVR. the trees are lousily in MD...but a lot of sheet good suppliers. Let me know.
Dave, amazing piano and great vocals on the 125's.
Old 15th October 2012, 04:34 PM   #134
jonparkhurst is offline jonparkhurst  United States
what is the fs of the 125 in OB?
Old 16th October 2016, 08:20 PM   #135
killmister is offline killmister  France
I revive this old thread because i have obtained good result with a notch filter. I went on mh-audio.nl - Home for calculate a filter the most narrow as possible. The calcultor gave me : 0.033 mH, 16,2 uF and 17 ohms for 10 dB damping at 7khz. Then, i made a coil by hand , welded it with the caps and made a try. Bad result ! Rather no result at all, the filter was more like a wire. I made an impedance measurment with speaker workshop . The graph showed me that the filter was centered at 5600 Hz . I decreased by steps of 1 uF several times until the notch was centered at 7 kHz with the measured value of 12,9 uF. Then, i made a second try and i figured it out this time, harshness was dissapeared with no bad effect. The high was a bit laid back but i have no put any resistor. I plane to put 15 ohm. I'll post some pictures soon.
Guillaume
Old 17th October 2016, 05:38 AM   #136
Hi !
Impedance measurement with notch (in enclosure) :
Old 17th October 2016, 01:11 PM   #137
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Nice result. Do you have speaker frequency response measurement after filter applied?
Old 17th October 2016, 02:32 PM   #138
Hi !
Unfortunately no because i haven't any acoustic measurement tool but, believe me, the speaker becomes more listenable with this filter . The sound is more relaxed and less colored and without any harshness. The medium frequency seems to be more focused too with a better 3D.
taming harshness of fostex FF125WKHide this!Advertise here!
Taming harshness in horn tweeter rongon Multi-Way 173 4th October 2014 05:14 AM
ff125wk vs w4-1337sdf (ferite) norman bates Full Range 59 1st August 2012 10:21 AM
FF125WK and Fonken efreddi Full Range 5 13th March 2012 11:37 PM
Planet 10 FF125wk dFonken125T 0v8 jonparkhurst Full Range 74 13th February 2012 05:15 PM
Speaker enclosure for FF125WK vintvolt Full Range 14 12th December 2011 08:25 PM
