Effects of changing BL of drivers
Old 28th August 2012, 08:24 AM   #1
lyedavide is offline lyedavide
Smile Effects of changing BL of drivers
Hi everyone, this is my first posting. I've read some papers published by the AES suggesting that, by increasing the BL of a given size (by changing its ceramic magnets to neodymium of the same physical size), produces a significant efficiency in the mid to high frequency output of the driver. Has anyone experimented to test the viability of this? I plan to do just this on an old woofer that need rebuilding. Any help, suggestions and research materials will be very much appreciated. Thanks
Old 28th August 2012, 01:28 PM   #2
IG81 is offline IG81  Canada
IG81's Avatar
It is an accepted fact that drivers with strong motors will often have an apparent rise in midrange and high frequency sensitivity, but I think it's actually the other way around, where the strong motor acts as an electro-magnetic brake for low frequencies, when the cone has more travel.
IG
Old 28th August 2012, 01:29 PM   #3
Keriwena is offline Keriwena  United States
I have two drivers, ostensibly the same, one of which has a neo plug that increases the Bl by about 20%. Mids and highs may be about 1 dB louder. But the neo version has a Vas almost 3/4s the size of the other, and a 12% higher Fc (slightly lower Qts, as well). My thought is, the biggest difference will be in the cabinet size needed.
Old 28th August 2012, 09:50 PM   #4
Don Hills is offline Don Hills  New Zealand
Research has been done on this.
"Direct-Radiator Loudspeaker Systems with High-Bl"
by John Vanderkooy, Paul M. Boers and Ronald M. Aarts
It's an AES Convention paper, available for free download.
Search the Web for "aar03c4.pdf".
Old 28th August 2012, 10:15 PM   #5
R.I.P.
Hi, Viability versus the bog obvious, take the latter any time, /sreten.
Attempts to improve drivers by motor changes usually fail miserably.
Old 28th August 2012, 10:58 PM   #6
Thanks for the link to that article, Don.
It's always comforting when my observations coincide with the work of respected theorists. It's all too easy to measure a fluke and think it's the whole whale.
Effects of changing BL of driversHide this!Advertise here!
BL units for Markaudio drivers pizzachef Full Range 3 5th August 2011 11:17 PM
Mutiple drivers in a TL, same BL? PeteMcK Multi-Way 3 23rd August 2010 03:47 AM
High BL drivers. Acoustic Absorb Subwoofers 0 10th March 2006 09:38 PM
Thinking of changing drivers paulc Subwoofers 5 27th February 2006 03:23 AM
Changing spacing of drivers on adire bang dvdwmth Multi-Way 4 9th September 2004 03:20 AM
