How you go low? - diyAudio
Old 23rd August 2012, 10:13 PM   #1
Default How you go low?
Liitle problem with dipoles, how you deal range 20-60 ? any sugggestions? ib baffle or another element suckin another?
Old 23rd August 2012, 10:34 PM   #2
DougL is offline DougL  United States
IB is great if you can do it.. The other solution is Multiple conventional subs.
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 23rd August 2012, 11:11 PM   #3
diyAudio Member RIP
What is the question ? Dipoles can go very low at modest volumes.
rgds, sreten.
Old 23rd August 2012, 11:25 PM   #4
5th element's Avatar
As sreten says, if loud spls aren't a requirement then a decent dipole can get you very low (mine always did). If you are after high SPLs and you must use dipole main panels, then using them down to ~40Hz, with a standard monopole for everything below, is definitely the way to go.
As DougL says though mutiple subs do work extremely well. I've used both dipoles and mutple subs and prefer the latter by far. It looks better, sounds better and can give real output where it counts for movies.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 24th August 2012, 08:31 PM   #5
rgds, sreten.
Extreme Volumes are the main problem, ib is for me only solution, whole systen is dipole based, whits is doing 124 db, over 100 hz, is there any solution make normal dipolesubs working enough hard to make such kinds of decibels, this is like overengineering, 110 db would be fine if there is no crack in the voice, but i prefer "little" headroom
Old 24th August 2012, 09:01 PM   #6
tsiros is offline tsiros  Greece
tsiros's Avatar
Send a message via MSN to tsiros Send a message via Skype™ to tsiros
It's very very difficult (i ignore, for now, that it is not even that much important) to go below 40Hz even with closed cabinets. I'd hazard a guess that with a dipole arrangement, it would be even more difficult. Maybe if you sit close to the speakers it could be easier?
Old 24th August 2012, 09:24 PM   #7
diyAudio Member RIP
124dB dipole above 100Hz ... !? And a bass system to match .... !?
Yeah right .... What dipole remotely does 124dB above 100Hz ?
rgds, sreten.
Old 24th August 2012, 09:58 PM   #8
It's kind of an easy question. This is what you build, many have already. I think it will go beautiful with dipole:
Build your own 2x12" TH (The Kraken 212 TH)
/Erling
Old 24th August 2012, 10:06 PM   #9
tvrgeek is offline tvrgeek  United States
You are essentially omni-directional as soon as the wavelength is longer than the baffle, and unless your dipole is 30 feet wide, this is a moot point. Just build a nice well behaved sealed sub.
Physics, not just a good idea, it's the law.
Old 24th August 2012, 10:12 PM   #10
/Erling
Interisting idea, but does bass quality match with pure dipoles, or are you thonkin that the ear sensitivity in those freququnsies solve the broblem?
Low noise, low microphony, low hum valves MarcelvdG Tubes / Valves 38 28th January 2013 08:42 PM
JL 1000/1 Slash v1 Has low ohms and low volts light on superjoey01 Class D 1 15th July 2012 04:14 PM
Passive Radiator for Low Excursion, Low Displacement & High Sens Woofer? goody75 Subwoofers 15 7th May 2012 08:07 PM
given choice of low screen voltage or low bias which sounds better or is it equal ryuji Tubes / Valves 2 23rd March 2012 01:32 PM
preamp supply LOW power LOW noise LOW cost drdagor Power Supplies 1 13th September 2010 11:39 PM
Copyright 1999-2017 diyAudio
