Frugel Horn for Lowther drivers
Hi, I've looked for this argument inside the huge thread about FH3 but I've found nothing.
I love Lowther drivers and I'm always looking for alternative plans than Lowthers' FH3 are very beautiful nd quite easy to build but they seem to be suitable only for small drivers. Are there any calculator for these cabinets as well as TQWT or BiB? Thanks in advance. Regards Ziocalepino |
Glad you like them, but no, no calculators I'm afraid. The design configuration does not lend itself to larger units, Lowther or otherwise. What units did you have in mind?
I have a pair of Lowther C45 that I'm actually using on Accolade cabinets together with PM6C. Because of theri high cost it is very difficult for me to sell Accolade, more simple is sell Acousta with PM6C. So I remain with two C45, for which it exists a Lowther cabinet that I've built and destroyed because of its ugly sound. So I'm looking for alternative plans for C45 drivers.
Thanks for answering. Bye Zocalepino |
Ah, if it's the C45, things become a little different.
You'd need a suprabaffle to make them physically fit, since according to the dimensions on the Lowther site they'd otherwise be a little wider than the FH3 cabinet, but otherwise, based on the published specs., the C45 looks to me like it should go in with a reasonable chance of working quite well. Q, Vas and Fs all look to be in the acceptable ballbark. I would probably be inclined to treat them in a similar way to the FE126En, i.e. corner-loading is likely to be preferable. |
Well but what do you mean saying "corner-loading is likely to be preferable"?
It means I would expect that, like the FE126En, they will work best if corner loaded.
corner loading = placing the cabinets at opposing room corners along the same wall at rougthly ~45º to the 90º corner. in doing so the walls act as the last horn fold thus producing greater LF extension. FH3 is i believe a corner horn by design which can work with or without corner loading but best with.
It won't produce all that much more LF extension per se, since this is ultimately a function of the axial length of the horn, but it will increase the useable gain BW & lower Fc.
...ah ha i get that, thanks.
| All times are GMT. The time now is 09:43 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
