#11 | |
I might be wrong in this assumption, not sure! Ray |
#12 |
Ray,
You are correct on the A 10.2 being able to produce more bass. IIRC the drivers require larger cabs than what you had mentioned in your first post. - Zia |
#13 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#14 |
Not if he utilizes an aperiodic vent.
I LIKE YOU
#15 |
frugal-phile(tm)
Aperiodic vent just lowers the Q.
What i was getting at is that it is a complex system and that saying that given 1 dimension, driver size in this case, will result in more bass is not the case. dave
#16 |
Yes, larger drivers are not always the best way to get more base, but I believe in the case of going full range, they will prevent the Doppler effect for high frequencies (garbling) while still being capable of producing base. Where as a smaller driver has to work harder and use more excursion causing more ID.
Also the larger diver is more sensitive for his t-amp. He can get a butterworth 2nd order alignment with 7 lt. If he goes aperiodic, And have a -3 at 40 hz in his small cabin.
I LIKE YOU
#17 |
While I am not on top of Thiele Small Parameters and don't pretend to understand them I realize that a larger diaphragm will have the capacity to move more air and will have the potential to produce more bass with less driver excursion.
Conversely a smaller driver with a much greater driver excursion COULD potentially provide more more base if the excursion is great enough. That's my simplified grasp and I think it's somewhere around correct without to much in the way of mathematics and equations which have the capacity to confuse me terribly. |
#18 | |
frugal-phile(tm)
But no matter, F3 is mostly meaningless except for the filter theory (Toole), but with an F10 of ~70, and the assumption that aperiodic will bring the Q down to butterworth (enuff damping would as well), 40ish flat is a reasonable guess. dave
#19 |
I use the ct218 build on my ta2020 whit great pleasure. Small, cheap...,quick to build, papercone here is the link Strassacker: Lautsprecher - Boxen - Selbstbau.
| Advice for enclosure volume, driver size and porting? DIY coffee table subwoofer | ciper | Subwoofers | 8 | 21st May 2012 01:38 AM |
| Looking for suitable small speakers | Telemin | Full Range | 19 | 14th June 2009 11:38 PM |
| Box volume on WinISD/BCAE seems way too small | BMW M5 | Car Audio | 5 | 21st September 2005 06:15 AM |
| Which driver for a small sealed box. | ShockValue | Subwoofers | 21 | 16th June 2005 04:25 PM |
