And so it begins. Fostex FE166En + BiB - diyAudio
Old 16th August 2012, 11:26 PM   #1
N4BBQ is offline N4BBQ  United States
N4BBQ's Avatar
Default And so it begins. Fostex FE166En + BiB
These arrived today.
My BiB plan is to build a hybrid BiB with the front, back, baffle, and bottom of MDF and the sides with pressed oak plywood.
I'll try to keep a photo log going here.
Old 17th August 2012, 02:35 AM   #2
zman01 is offline zman01  Bangladesh
N4BBQ,
Why MDF? BiB is a big cabinet and the extra stifness plywood will give will come in handy. Also MDF is heavier, and these boxes can be pretty heavy (I built a BiB with FE166EN last year).
Old 17th August 2012, 10:55 AM   #3
N4BBQ's Avatar
Originally Posted by zman01 View Post
N4BBQ,
You're spot on about it being heavy. I donno. I guess the price got me. Our local Home Depot had some nice 3/4 on sale at $19/4x8 sheet so I bought two sheets of that, but I want a nice wood side, so I decided to use the Oak plywood for the sides. I plan to finish the front black and that should make for a nice looking speaker.
I won't have to worry about anyone rushing in and stealing them (unless they are a weight-lifter).
Are you enjoying your build? What amp are you using with them?
Old 17th August 2012, 01:07 PM   #4
N4BBQ,
I had built the BiBs for a friend. The speakers were at my place for some time, and I was using a Miniwatt N3 and another El34 single ended amp with it. Both were a good match with the Fostex drivers.
The BiBs were very enjoyable to listen to - my first brush with full-range speakers in fact. Since I liked them went on to quite a few other builds.
What amp do you have/plan to use?
Old 17th August 2012, 01:31 PM   #5
N4BBQ's Avatar
Very good. I'm sure the same will happen to me (on to other builds).
I just finished a single-ended 6N3C (6L6) amp.
The speakers I have now are old Infinity RS-6000s (but the woofers had been removed and replaced with some JBLs of some sort), so I'm looking forward to the Fostex build to see what sort of a difference there will be.
Old 17th August 2012, 01:54 PM   #6
Godzilla's Avatar
Keep us posted on your BIBs!
Old 17th August 2012, 03:55 PM   #7
N4BBQ's Avatar
I will. I've been reading and thumbing through build pictures.
What is the opinion of using dampening material anywhere in the cabinet?
Old 17th August 2012, 05:15 PM   #8
frugal-phile(tm)
planet10's Avatar
12mm quality plywood would give a better result (and i wouldn't use less then 18mm (~same as 1 1/4" MDF) in a build this big (unless very well braced)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th August 2012, 05:31 PM   #9
N4BBQ's Avatar
dave
Thanks for the tip.
BUT, I've already cut all the stuff...but looking at the bright side of that, there's always the next BiB made with all plywood and possibly a different speaker.
Old 24th August 2012, 09:58 PM   #10
N4BBQ's Avatar
A few parts that are cut & dry waiting on a few other parts to dry.
Question : How has others routed their speaker cable inside the cabinet?
Fostex: FE164 vs FE166en robber222 Full Range 14 12th June 2015 03:50 PM
Fostex F120A in BIB Kenny Brant Full Range 12 1st December 2011 01:34 PM
Onken for Fostex FE166En ziocalepino Full Range 15 2nd September 2011 07:10 AM
FOSTEX FE166En drivers for sale Toppsy Swap Meet 3 31st August 2011 04:00 PM
Fostex BIB Greendan Full Range 3 29th April 2009 07:48 PM
Copyright 1999-2017 diyAudio
