And so it begins. Fostex FE166En + BiB - Page 3 - diyAudio
Old 28th August 2012, 02:16 AM   #21
GM is offline GM  United States
GM's Avatar
Can't say I'm surprised......
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 28th August 2012, 09:55 AM   #22
Vix is offline Vix  Yugoslavia
Vix's Avatar
Originally Posted by N4BBQ View Post
I'm amazed. Even my wife noticed! haha
This should be your next project :
BBBIB Bigger Badder BIB Speaker
Old 9th September 2012, 04:10 PM   #23
Can you tell me the dims you came up with (internal)?
want to check against my own BiB calculator.
Also the number i came up with has a height of 65", if i cut it down to 60" so i can use 5x5 bb ply what will happen, less low end extension?
Altec Lansig computer speaker amp, Paradigm atomss, Altec computer sub, Windows PC source
Old 10th September 2012, 05:39 AM   #24
Well it seems the EL70 scarce so i looked at the TB w4-1052-4ohm.
the cab is almost identical in size to the one for the 166en.
It has 4mm xmax and i will prob use a pair in each cab for 8ohm and increased output.
Prob not as sensitive but shell prob be using 50w per side solid state power.
Old 10th September 2012, 12:53 PM   #25
N4BBQ is offline N4BBQ  United States
N4BBQ's Avatar
G'morn,
I used the BiB Calculator v2 and cut the boards as close as I could to what it gave me. I'll attached that file to this message. This is not my file and I'm not a good person to ask about the effects of making changes. I'm a newbie to building speakers. There's a lot more experience on here and maybe one of those guys will chime in with some help for you.
Old 30th August 2014, 01:58 PM   #26
gychang is offline gychang  United States
Originally Posted by planet10 View Post
12mm quality plywood would give a better result (and i wouldn't use less then 18mm (~same as 1 1/4" MDF) in a build this big (unless very well braced)
dave
little confused about the 1 1/4" size?
Good sound from Davis, CA
Old 30th August 2014, 02:26 PM   #27
GM's Avatar
We ideally want the cab to 'ring' outside the speaker's loading BW, so easier to push the cab's Fs above the HF corner frequency than below its low corner when it's the [mid] bass by making it stiff/rigid enough.
3/4" [19 mm] MDF has a modulus of elasticity [MOE] = ~527,000 psi on average while BB, apple and marine ply = ~1,800,000 psi on average.
MOE increases at the cube of thickness, so MDF needs to be ~1-1/8" thick, but isn't available AFAIK, ergo best to increase it to 1-1/4" than using 1".
18 mm comparisons would be slightly less, but MDF still ideally needs to be over the 1", though considering the low max pressures of a small 'FR' driver, it should be OK, especially if a little bracing is used to support/mass load the driver and also stiffen up the terminus like done on bass horns.
GM
Fostex: FE164 vs FE166en robber222 Full Range 14 12th June 2015 04:50 PM
Fostex F120A in BIB Kenny Brant Full Range 12 1st December 2011 02:34 PM
Onken for Fostex FE166En ziocalepino Full Range 15 2nd September 2011 08:10 AM
FOSTEX FE166En drivers for sale Toppsy Swap Meet 3 31st August 2011 05:00 PM
Fostex BIB Greendan Full Range 3 29th April 2009 08:48 PM
Copyright 1999-2017 diyAudio
