I recently built a pair of Overnight Sensations for use on my computer desk. They sound good, though I think I can do better. Plus, DIY speaker building is kind of fun.
![]() I've combed through a lot of the similar "desktop/nearfield suggestion" threads here, and lots of people recommend full range drivers for this purpose. In particular, I see lot of suggestions for "mFonkens" or "uFonkens" or "mMar-Kel70" as well as variations on these. I haven't been able to find a consistent set of information on these designs. I was hoping someone could maybe dumb it down for me, and give a simple overview (like the Overnight Sensations page I linked). I'm still effectively a complete newbie to DIY audio. What I'm looking for is speakers that are no more than 7" wide, 9" deep, and maybe 12" tall. I could be flexible with depth and height, but 7" is really the max for depth. Also, with the specific models named above, and small FR speakers in general, it's been hard to find what the bass response is... I haven't seen any "F3" numbers. A lot of posts hint at, or explicitly say, "you need a sub". I'd really rather not have a sub. I'd also rather not EQ, as I send "bit perfect" CD audio data out to a DAC, and then to an amp. I don't need crazy bass, but I'd like to have usable bass at least down to 50Hz. Amp will be a HiFiMeDiy T2 (TK2050, 50W at 8Ohms, 100W at 4Ohms). I listen to all kinds of music, dominated mostly by rock and metal, but with healthy amounts of blues, classical and trance. Thanks! Matt |
#2 |
frugal-phile(tm)
All the designs mentioned are mine.
milliSize me..., fonken-style box nomenclature... what is with those names?, miniOnken/Fonken gallery pictures only Unless you have a lot of room gain, or a VERY inefficient speakerm or use EQ (on a sealed box), you are going to be challenged to get that bass out of a real small box (you dimensions max out at ~7.5 litre, the millSize boxes are 4.7 litre). Note that F3 has been shown to be pretty much meaningless in terms of what you here, F6 or F10 are mire meaningful. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 | |||
I gathered that in my research... Almost posted this in the dedicated planet10 forum, but I thought I'd keep it more general.
), the theory is that multi-way speakers are sub-optimal for nearfield listening.If it's not obvious, I have little experience, and my "knowledge" comes from lurking on forums. FWIW, I did dabble with FR speakers a long time ago. But that was a mostly different application, with different goals. And (as always?) if I knew then what I know now, I probably wouldn't even have attempted that build. Quote:
Thanks again, Matt |
#4 | |||||
frugal-phile(tm)
Given the size you can live with, and your wish for bass, it may be time for me to finally get around to the dmMar-Kel70 (~7 litre EL70 box -- could be in the mold of the millis or a full-on miniOnken with side vents & big champhers (better but a more challenging build). Of the milliSize, EL70 produces the lowest bass (and is superb bang for the buck). In the milli it sounds great but you get the feeling that the cabinet size is holding it back (it is). Quote:
If it's not obvious, I have little experience, and my "knowledge" comes from lurking on forums. Quote:
dave
#5 | |
Also, I didn't see any picture... Other than power requirements, is there any downside to inefficient speakers? Seems like nearfield+high power requirements kind of balance each other out. |
#6 | ||
frugal-phile(tm)
How loud? & what kind of music? Near field use plays to FRs strengths and minimizes their downsides.
![]() Note that these only (just barely) do 80 Hz. Quote:
dave
#7 |
A manufacturers needs to make a 3 or 4" super bass awesome full ranger that's only 75db/watt. Give up the efficiency for bass in the near field. Not sure that is even possible, but I'd be interested in it.
To the OP, I think you'll find any of the mark audio designs of Planet10s to have adequate bass in the near field. Don't forget that you get desktop support for the woofer just like you would get floor support in a 3-way in the far field. I've heard a lot of his designs and they make bass. |
| Twin Chr-ken70.3 Castle teaser | Coffeebass | Planet 10 hifi | 23 | 4th May 2012 11:06 PM |
| mMar-Kel70 in Chile | AlejandroR | Full Range | 0 | 17th August 2011 01:56 PM |
| uFonken Padding | nukaidee | Full Range | 12 | 22nd September 2010 11:51 PM |
| Fat ufonken build | jpbturbo | Full Range | 7 | 9th November 2009 01:20 PM |
| mini surround sound setup plan for nearfield | iyo | Chip Amps | 0 | 16th October 2003 09:23 AM |
