A Big'un - the Audio Nirvana Super 15 - Page 4 - diyAudio
Old 14th August 2012, 11:14 PM   #31
norman bates's Avatar
it is sort of like tweaking out am powerless radio. Getting the most out of it with tweaks. You are right, that's a big box for 1mm xmax, but if we are going for that driver by itself, you do what you do to get the most out of it, rather than 1.5 way, or 2 way with 6db, or worse (a 12db or more, yuck).
I think of the fridge sized boxes used for the urei coax time aligned monitor from jbl with its weird ladder delay circuit.
Didn't most of the old 15" with whizzers have huge boxes back 50's and 60's ?
Once you add xmax, the inductance goes up, and there goes your mids and highs. Then again, adding a copper cap or shorting ring, you may be able to offset the longer xmax. That would be a bunch of trial and error. I remember Paul at Wild Burro commenting that he tried either copper cap or shorting ring but the highs were way too strong.
Norman
Old 15th August 2012, 12:50 AM   #32
doggy is offline doggy  Canada
doggy's Avatar
The "boffle" looks intriguing, baffles provide resistance to air flow, like the ports on the onken design?
Old 15th August 2012, 01:05 AM   #33
Default Boffle step
Sorry. I don't know why this beast interests me but I'm guessing that with a helper bass driver on the back you'd need zero bsc and party down in front. Big is Badass.
Old 15th August 2012, 01:31 AM   #34
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by Melon Head View Post
keep going bigun
Originally Posted by Cal Weldon View Post
You know I love big speakers but I must say I am having trouble wrapping my head around a refrigerator sized box and a 1mm Xmax.
this is the price to pay for using a single driver I fear. On the other hand, 1mm with 15" is a lot better than 0.5mm with 4" Fostex !
I think more like an OB but with the back wave absorbed so that there's much less dipole dip-and-bump to worry about. Or perhaps more like IB. Either way it does look worth trying so the bracing has to designed to allow for it. Of course, there won't be any bass reinforcement from the box with this setup.
Yup, that would be interesting!
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 15th August 2012, 01:41 AM   #35
Bigun's Avatar
What thickness of plywood to use for the box? I can buy 11.5mm and 17mm thick panels. I can glue panels face-to-face. But I'd rather brace the hell out of it than have panels that are so thick and heavy that I can no longer move it without help from a neighbour.
what if the box was made using only 11.5mm panels and then lattice braced ?
the floors in my house use wooden i-beams, very stiff (much better than my last house that used regular joists) and lightweight (photo) and much more practical than using thicker and thicker floor boards.
Old 15th August 2012, 02:26 AM   #36
frugal-phile(tm)
planet10's Avatar
The boffle i was thinking of could also be described as a damped U-Frame
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th August 2012, 05:20 AM   #37
GM is offline GM  United States
GM's Avatar
Yeah, 8 ft^3 was about the smallest I remember with 12-15 ft^3 being the most common. As late as the mid '70s I was putting cheap 8"ers in up to 7 ft^3 MLTLs to get enough bass out of them to do DSOTM and the few other LPs that got down into the low 30s.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 15th August 2012, 05:31 AM   #38
GM's Avatar
Braced with I-beams, you can use 1/4" [6-7 mm], but that would be a lot of work, so the 11.5 mm is doable.
Frankly, minimally braced 1/2" ply was typical for this type of driver in a big cab as any 'breathing' the cab did helped to damp its high Q. You can always go back and add bracing if you don't like how it performs.
GM
Old 15th August 2012, 05:53 AM   #39
freddi is offline freddi  United States
freddi's Avatar
although its motor is small/weak, you could put it into a Karlson enclosure from K15 to K18 size. Coat the front chamber well with varnish, etc. and enjoy.
Old 15th August 2012, 08:01 AM   #40
mondogenerator's Avatar
dave
that just looks like a labyrinth to me dave, albeit one with a vent area equal to baffle area. Ignoring semantics tho, it would be worth a try.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Audio Nirvana Super 15" cast frame build mikeineugene Full Range 10 16th October 2011 04:36 PM
audio nirvana super 10 or super 12 tonytex Full Range 11 4th September 2011 10:55 PM
Audio Nirvana Super 3 GMark Full Range 8 11th May 2011 06:03 PM
Audio Nirvana super 8 nirvana Full Range 10 19th July 2010 10:07 AM
audio nirvana super 8 cascadeguy Full Range 21 25th March 2007 03:11 PM
Copyright 1999-2017 diyAudio
