A Big'un - the Audio Nirvana Super 15
Old 4th June 2013, 12:16 AM   #331
Bigun is offline Bigun  Canada
Bigun's Avatar
Yes, it ended up full sized. Probably it's a bit larger than what I forecasted. The idea is to ensure it's large enough that 'aperiodic' is not required.
And I agree, sealed should be very good. This was my original design intent. But open back boxes are also of interest so that is why I'm exploring both options.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 4th June 2013, 01:26 AM   #332
norman bates is offline norman bates  United States
norman bates's Avatar
foam ? like the grey finger stuf at parts express, but sandwiched together so it is thicker.
Wow, that'd be a big, big box. The qts and the vas makes it like the fifteen inch "woofers of old" needing 15ft3 for porteds, eek.
Found this on low bass coming from a too small open baffle.
Sideways Dipole Bass
post #24
"If wavelength become larger (say >1m for "small rooms"), the dipole no longer shows its figure 8, but increasingly feeds the inidividual room modes only. The bass you will get at a certain position in the room will be the bass which the room modes produce there. That is the same procedure as for other bass loudspeakers, but with a somewhat different mode excitation."
Explains why your 2' deep open baffle seems to have some low bass.
I like your box design.
It one of the only options for that driver (in my opinion).
interesting........................
Norman
Old 4th June 2013, 06:58 PM   #333
burgunder is offline burgunder  Denmark
Perhaps you should try to dampen the backwave like this Mpl
Old 5th June 2013, 11:55 AM   #334
Bigun's Avatar
I have put some old clothes in the back of the box to absorb the high frequencies - a poor mans Boffle but I need to do some more experiments. The day job keeps me a bit occupied but perhaps this weekend will yield some time to play.
I don't think the uneven bass response will be acceptable if I keep it open backed, some kind of EQ will be needed. It might be possible to implement a line level passive EQ, or perhaps I should go 'modern' and get one of those miniDSP gadgets to play with ?
Old 5th June 2013, 12:18 PM   #335
IG81 is offline IG81  Canada
IG81's Avatar
MiniDSP is pretty great. It might matter to some that they can't say they listen 100% analog anymore, but it certainly does not ruin listening to vinyl for me; I don't think I could tell if I didn't know. In your case though, I'd try to find the best acoustic solution before going with electrical corrections. Since you went for the full-size build (I assume 13.6cu.f), you already have a nice medium sealed Qtc and might only need some lining on the walls. Model shows f3 in the mid 40ies, not too shabby.
IG
Old 9th June 2013, 09:17 PM   #336
Bigun's Avatar
I will be working on a non-DSP signal chain for now, for sure.
Interesting - I didn't know there was a new hi-end speaker manufacturer in Canada using the Audio Nirvana (I think the largest size is 12" though): RJH Audio Extremely Efficient Full Range Single Point Source Loudspeakers for the Discerning Listener.
Old 10th June 2013, 09:52 AM   #337
Didn't you said you'd seal the rear a half a year ago ?
I know that's "the pot calling the kettle black" as I have many an unfinished projects.
Norman
Old 7th September 2013, 07:55 PM   #338
Bigun's Avatar
Well I actually put the back on the box for the first time today. I fit some batting on some of the internal surfaces and took out my kids old clothes before I bolted on the back.
I also had to fit a terminal cup.
My tube amp isn't sounding so good these days, maybe the tube is getting old. So I popped in my Bryston BP60 to listen to the top 40.
Strange thing - seems to me that there is less bass. The sound is very clean but the balance is tilted up. The back may have to come back off...
Old 7th September 2013, 10:33 PM   #339
freddi is offline freddi  United States
freddi's Avatar
if they generally meet spec then one should play in a Karlson 18 the size of the Cetec-Gauss 5181 cabinet - it needs a stronger motor to do best in K15 but would probably sound pretty good in one
5181 plan - the rectangular indications on the sides were pockets for carrying handles. It probably would not hurt to open up the starting gap a bit
http://img72.imageshack.us/img72/825/gaussbracing.jpg
Old 8th September 2013, 01:15 AM   #340
maybe that the ob has more midbass, tricking the ear/brain to think there is more low bass (like a bass guitar or a max-bass effect box).
My "phy style" hinged open baffles are penned in for october.
I love my phillips crossed at 100hz.
Sand filled walls, not fun.
Norman
A Big'un - the Audio Nirvana Super 15Hide this!Advertise here!
Audio Nirvana Super 15" cast frame build mikeineugene Full Range 10 16th October 2011 04:36 PM
audio nirvana super 10 or super 12 tonytex Full Range 11 4th September 2011 10:55 PM
Audio Nirvana Super 3 GMark Full Range 8 11th May 2011 06:03 PM
Audio Nirvana super 8 nirvana Full Range 10 19th July 2010 10:07 AM
audio nirvana super 8 cascadeguy Full Range 21 25th March 2007 03:11 PM
