Old 14th August 2012, 12:58 PM   #11
Bob Brines's Avatar
Originally Posted by mondogenerator View Post
....Couldnt you reverse eng to guesstimate, scott? Im not sure there are any secrets any longer!
I think that Scott was referring to what the designer specified as opposed to what is really required. At least that would be my question.
Bob
Old 14th August 2012, 01:47 PM   #12
Bigun is online now Bigun  Canada
Bigun's Avatar
are we sure that we even want a vent ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 14th August 2012, 03:32 PM   #13
Scottmoose's Avatar
You read my mind Bob
It depends what you mean by 'vent' but assuming you are talking about a hole in the box (irrespective of whether it has a duct or tube attached), and again assuming the published data is representative, I would say almost certainly not, unless it's tuned so low that it provides zero useful output. The cabinet is too small to be vented (at least, under the further assumption that a reasonably accurate response is desired).
Old 14th August 2012, 03:50 PM   #14
mondogenerator's Avatar
right. Ok. My mistake. Sometimes i regret writing. Anything. Lol
It still amazes me every time I get something right
Old 14th August 2012, 04:27 PM   #15
Bigun's Avatar
exactly.
Looking at the AN15, the published Fs is already low enough, no need for a resonant port to extend it lower. And I already ruled out adding a 2nd driver, which a tuned port becomes, albeit with a mechanical cross-over.
Old 14th August 2012, 04:43 PM   #16
GM is offline GM  United States
GM's Avatar
What?! No ~aperiodic vent to 'tighten up' this under-damped alignment? Also, FWIW, the pioneers of audio determined that from an acoustical loading POV of point source drivers that the cab's net Vb should be whatever raised its Fs 1.56x, be it sealed or vented, or ~15.15 ft^3 based on the published spec. No clue whether there's any audible difference between 13.6 and 15.15 though. My SWAG is it would be very room, signal source dependent.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 14th August 2012, 05:07 PM   #17
Bigun's Avatar
My local store stocks Baltic Birch in 2' x 4' sheets. With almost no cutting this makes for a Vb of 16 cu.ft. - less volume of the panels, the driver, and bracing. It's probably going to end up closer to the 13.6 than 15 but I figured this still allows an Fc around high 30's which is just fine.
Damping - adding resistive ports to the back panel could be experimented with as the back panel will be removable & replaceable
Old 14th August 2012, 05:47 PM   #18
frugal-phile(tm)
planet10's Avatar
I did the 1st pass on an An-Ken for the 15, constrained by the wxd restraints posted by an interested party and they would have needed to be 3m tall. Set that aside for now.
Thinking of a practical box that isn't an OB (which i have never been enamoured of), i was figuring a couple hundred litre, box damped like a boffle with a swiss cheese back (you need a back to make the box structurally strong).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th August 2012, 06:05 PM   #19
GM's Avatar
'Sounds' like a plan!
GM
Old 14th August 2012, 06:49 PM   #20
Scottmoose's Avatar
Yep, that's going to be favourite.
GM
+1. Since the CSA plans were mentioned, I was largely just dreading they were going to be run as a BR (since their record isn't great when it comes to box alignments ).
Audio Nirvana Super 15" cast frame build mikeineugene Full Range 10 16th October 2011 04:36 PM
audio nirvana super 10 or super 12 tonytex Full Range 11 4th September 2011 10:55 PM
Audio Nirvana Super 3 GMark Full Range 8 11th May 2011 06:03 PM
Audio Nirvana super 8 nirvana Full Range 10 19th July 2010 10:07 AM
audio nirvana super 8 cascadeguy Full Range 21 25th March 2007 03:11 PM
Copyright ©1999-2013 diyAudio
