A Big'un - the Audio Nirvana Super 15
Old 17th August 2012, 02:38 PM   #101
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
Originally Posted by Bigun View Post
this seems just as viable to me - if there's a shelf brace connecting the front panel to the other panels just below the mounting of the driver then it essentially couples the driver to all sides of the box.
Where is the shelf brace attached? If its to the front panel below the driver it has no real effect on the driver per se - just the baffle to which it is attached.
By making a solid contact with the reverse of the magnet the 'holey brace' transfers movement/vibration to at least one other panel - the back (more if possible), and is mechanically linked to the front panel via the frame to several mounting points in a 15" circular pattern which gives better control than a straight bar across the front. The magnet & frame become part of the brace.
The shelf just splits the baffle into 2 peices that vibrate semi independently of each other and then need controlling again. Especially in such a large cabinet. The frame in such a large driver is subject to vibration and potentially movement (depending on material & build) and by 'sinking' this away to another, or several, panels it works as a better brace.
If I'm not making noise, I'm making something to make noise
Old 17th August 2012, 02:38 PM   #102
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by Melon Head View Post
I am thinking
yeah, I know, clutching at straws to find justification for a brace on the magnet. Seems like a belt and braces approach at best.
Originally Posted by JRKO View Post
Where is the shelf brace attached? If its to the front panel below the driver it has no real effect on the driver per se - just the baffle to which it is attached....
If Melon is using CSA drawings, the shelf brace is horizontal, parallel to the floor, and about half way up the height of the box. It is attached along all 4 edges to the front, the back and both sides of the box. We can't publish the drawings as they are copyright and permission to publish them has been specifically withheld.
The cast driver frame is clearly substantial and strong. It connects the magnet to the front baffle. Melon and I were suggesting that bracing the front baffle near to the driver frame is equivalent to bracing the magnet in terms of the benefits that Planet10 is looking to gain from a magnet brace, i.e. it transfers vibrations from the driver to all sides of the box.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 17th August 2012, 02:53 PM   #103
Melon Head is offline Melon Head  Australia
Banned
If anyone tells you "this is not rocket science", tell them they don't know what they're talking about
Yes imagine a shelf like on a bookshelf but with holes in it
Old 17th August 2012, 03:06 PM   #104
JRKO's Avatar
Like an internal belt then? Like they use on box kites and packing crates? What does this thing brace against? Because unless there is a crossmember from front to back thru the middle, or side to side thru the middle, or very large triangular corner pieces its not really bracing. (unless its 12" deep)
Half way up you say? If its there to help reduce the vibration of 4 large panels, in the process created 8 smaller ones which are still very big on a box that size.
If I were undertaking a box this big having spent out on the AN drivers I'd do the holey brace for the magnet and several holey triangular braces. Then industrial rubber of various thickness sticking tile/mdf/ply to the various surfaces and jobs a goodun'
Old 17th August 2012, 03:11 PM   #105
Banned
There is a crossmember front to back and side to side
Old 17th August 2012, 03:15 PM   #106
Banned
Like this
Old 17th August 2012, 03:48 PM   #107
Bigun's Avatar
I like those boxes, how are you planning to finish them ?
Old 17th August 2012, 03:50 PM   #108
Banned
These are not my boxes. I was too lazy to get my camera out so I found a photo with the same type of brace
Old 17th August 2012, 03:54 PM   #109
JRKO's Avatar
back of the speaker is still gonna be vibrating around with no rearward sink.
go on. brace it. you know you'll feel better
btw those cabinets are way smaller than the 10cuft+ I thought we were talking about. Maybe 1/3 of the volume? nice tho
Old 17th August 2012, 04:08 PM   #110
Bigun's Avatar
I don't want to start off with a big brace onto the rear panel because I am hoping to find the time to try it with some variations on the themes of 'open back', 'boffled', 'aperiodic' which means keeping some flexibility. Maybe there's a way to accommodate all these things.
A Big'un - the Audio Nirvana Super 15Hide this!Advertise here!
Audio Nirvana Super 15" cast frame build mikeineugene Full Range 10 16th October 2011 04:36 PM
audio nirvana super 10 or super 12 tonytex Full Range 11 4th September 2011 10:55 PM
Audio Nirvana Super 3 GMark Full Range 8 11th May 2011 06:03 PM
Audio Nirvana super 8 nirvana Full Range 10 19th July 2010 10:07 AM
audio nirvana super 8 cascadeguy Full Range 21 25th March 2007 03:11 PM
