Just for fun, Super cheap line array using logitech drivers?
Old 8th August 2012, 01:22 AM   #1
Lunchietey is offline Lunchietey  Australia
Default Just for fun, Super cheap line array using logitech drivers?
Hi everyone,
I have a random idea for a cheapo line array. Please keep in mind I'm in australia and there arent many choices for drivers, and freighting them to australia is usually quite expensive.
I'm thinking of buying a bunch of Logitech x-530 speaker systems(you can buy them cheap second hand) and using the 2" drivers in them to make a line array(maybe 30-40 a side) and using the corresponding woofers from the subs as midbass woofers spaced up the side of the full range divers(3-4 a side)
It's just a project idea at the moment, thoughts? The will be driven actively using a normal stereo amp(100w /channel) and maybe a small t-amp etc for the top end. I can pick the sets up for less than $50 au a set meaning the full range drivers equate to less than $5 ea, and i get free 5" drivers. Theres very little available here in that price range, best I can find are 'gento' 2" drivers on ebay. I'd like to stick to small drivers, and space them edge to edge rather than 4" etc and need a tweeter. i can eq if necessary.
Thanks!
Old 8th August 2012, 11:08 PM   #2
Well I went out and grabbed a couple of sets to do a quick test.
Only real issue I see is driver mounting, just have to find the perfect hole saw size and I will either have to rear mount, or get creative behind the driver with chamfering to allow the driver to breathe. The sound of the little 2" is pretty good when driven by a proper amp, logitechs cheap amp isn't great, and the little plastic satellite boxes don't help.
Also surprisingly, the 5" sub driver looks as though it may be quite ok too. So there is promise in this idea! I'll have to get a couple more sets and start stripping them down. I will also begin construction soon and just fill the 2" holes as I find sets! From what I've bought, each driver is around $3!
Old 8th August 2012, 11:27 PM   #3
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Ask this in Multi way for XO help
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 9th August 2012, 08:00 AM   #4
I'll probably just go active 300hz to start and go from there?
Also as i have had good preliminary results, i have ordered 2 laser cut steel baffles from a supplier at work to mount them into, this steel baffle will be gloss black, drivers rear mounted, with stained hardwood side panels with a slot routered into them for the baffle to mount into. The hardwood sides will 'clamp' onto the steel baffle I'll use threaded bolts with chrome cap-nuts and nuts to hold it together/apart. It will be essentially open baffle and I'm thinking stereo dipole bass?
Old 9th August 2012, 10:24 AM   #5
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
If so, you're probably going to have very restricted dynamic range with only 3 - 4 those midbass units / woofers per channel.
As for the general concept though, sounds reasonable enough given the price involved.
Old 9th August 2012, 10:45 AM   #6
I'm going to use a different woofer now, those little 2" drivers can almost definately over power the 5" on a 10:1 ratio. I've settled on a 36 driver array, 50mm drivers are spaced 55mm centres and total speaker height 2200mm. It will be close to my ceiling! There will be a larger enclosure at the bottom, probably with a large number of small woofers front firing next to the main array. Will figure out what to.use soon. I also keep finding the Logitech dual driver speakers cheap without the subs so yeah, ill use something else!
I do have some 96db 200wrms p-audio drivers... Hmm
I want the 36 silver cones to be prominent, and the bass drivers to be kind of hidden, so exposed 2" cones, but the bass section all behind black cloth etc. I may have to fill a section at the bottom with sand etc as it will need stability!
Old 9th August 2012, 01:34 PM   #7
chris661 is offline chris661  United Kingdom
chris661's Avatar
I noticed that the 2" drivers seem to have a decent amount of excursion capability.
With 36 of them, you'd probably have enough volume displacement to just eq the bass down to, say, 80Hz, and cross to a proper subwoofer.
I'd try to buy up some of the X-230 systems - 4x2" drivers, plus the same woofer.
Might come in handy in getting more of those woofers together, but I'd expect 4 per side to be impressive.
Old 9th August 2012, 09:55 PM   #8
I've got 4 weeks to collect drivers before my cnc steel baffles are done.
Yeah I had one of the little drivers sitting on the tv cabinet crossed at 80hz to an Aaron sub120 dual 8" dub and even that sounds ok. I suspect qts is a bit high though so open baffle for the mids sounds like how I might proceed. I'm hoping the floor to ceiling array (about 100mm from floor to ceiling gaps) will give me a true array experience.
It's possible even 4 5" drivers a side MAY be plenty, but 8 6" might be better hahaha! I want huge dynamics and 'size' so I might just go straight for overkill first :-)
However I will do experiments with the 5" to see if 4 will give me the output I want. Reason being they come free and this is a budget project, trying to keep costs down! The cnc baffles will cost $75 au each but compared to drilling 72 holes accurately, its worth it!
Old 12th August 2012, 10:24 AM   #9
I have just over half of the 72 drivers I'm going to need. Why didn't anyone tell me it was so much work to strip so many computer speakers!
I have come up with some great ideas for the design, but ill keep them to myself until the baffles have been machined :-)
Wow, 144 terminals to solder, plus woofers! Phew!
Old 5th October 2012, 01:40 PM   #10
treuben is offline treuben  Australia
Photos dammit! I'd like to see this! 8)
Just for fun, Super cheap line array using logitech drivers?Hide this!Advertise here!
Cheap, Fun line array candidate? pjanda1 Full Range 2 18th November 2009 05:22 AM
FS: Line Array Drivers - 84 drivers only $200.00! Magnetar Swap Meet 1 23rd August 2007 05:34 PM
Can you say the new cheap line array boner is here? Feandil Multi-Way 0 21st April 2005 11:28 PM
Playing with cheap line array is fun! JinMTVT Multi-Way 18 25th September 2004 09:27 PM
Open Baffle Line Array - using cheap drivers giambi77 Multi-Way 4 26th January 2004 10:29 PM
