Take this hearing test.. - Page 4 - diyAudio
Old 7th August 2012, 03:14 PM   #31
SY's Avatar
Originally Posted by Bare View Post
TRY it without the "headphones"
I've seen that 'most' 18 yr olds cannot reach 18khz .
SOMETHING is clearly Wrong. Basic Human physiology precludes it. Unless Born on Krypton!
Get your A** to a competent audioligist and perhaps be entered in the Medical Journals OR have your self evaluation laughed at.
First off, please respect forum rules on language.
Second, irrespective of what you think "most" 18 year olds can do, many can do quite a bit better. I've known males in their late 20s who could verifiably hear 21-22kHz tones. Sure, it's not typical (I certainly couldn't), but it's not unknown.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 7th August 2012, 04:04 PM   #32
5th element's Avatar
Originally Posted by Rullknufs View Post
High frequency sine waves are not that comfortable, yes. But in music, what instruments can play this high frequencies?
Maybe some overtones from cymbals, flutes? I don't know.
That high up it's all about the harmonic structure. All instruments fundamentals are, if broken down, sine waves, the way the harmonics fall + the atonal components, is what makes a clarinet sound like a clarinet and an oboe sound like an oboe.
That isn't particularly helpful when it comes to specific frequencies, but as Bob said, a violin can play up to around a C8, which is two octaves above a sopranos top C. The top C has its fundamental placed at 1044Hz, placing the violins top fundamental at 4176Hz. Obviously then the second and third harmonics lie at 8.3kHz and 12.5kHz, not to mention the higher harmonics too.
So yes, some instruments do have significant content in the last two octaves, the brain however is quite capable at compensating, to a reasonable degree, when your ears don't function quite as they should. I am sure that a gradual reduction in your high frequency hearing over time goes by largely unnoticed, but if this continues beyond a certain point it's got to impact on the way things sound.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 7th August 2012, 07:09 PM   #33
dirkwright's Avatar
Originally Posted by Mooly View Post
Another good one here as it plts the shape of your response on screen,
Equal loudness contours and audiometry - Test your own hearing
Yeah, I've used that one before also. It's very good.
Old 7th August 2012, 07:53 PM   #34
Scottmoose's Avatar
Re harmonics / overtones, this might be of interest: There's life above 20 kilohertz! A survey of musical instrument spectra to 102.4 kHz This is not my field so I can't really make any comments worth making.
I have thanks. Last time was ~6 months ago in a friend's home studio. Lynn Olson Ariels with Scan Speak D2905/9500 tweeters. Same result.
I've seen that 'most' 18 yr olds cannot reach 18khz.
News to me. I am aware of some studies that showed significant HF loss in teenagers who have been regularly exposed to high SPLs for prolonged periods. No surprise there. Not all teenagers are though.
Hardly. People differ as do environmental factors. Some are fortunate enough to retain their HF hearing for longer than others, in the same way that some retain certain aspects of their vision for longer than others. You can confirm that with a good audiologist or univeristy with a specialist department. I have been extremely fortunate on both counts thus far, but with that in mind, I am also careful about both.
It seems to me you started this thread with the objective of 'proving' that most people are deaf above x frequency. This has been demonstrated to be inaccurate by several people, who have no difficulty hearing frequencies above the point you appear to believe possible. Since you were the one who set the (loose) test criteria insofar as you selected the site and test tones, and were presumably happy with their qualitative aspects, it's up to you now. You can carry on firing off frankly rather unimaginative insults, and continue believing that all swans are white. Or, as Carl Sagan said of Johannes Kepler,
'When Kepler found his long-cherished beliefs did not agree with the most precise observation, he accepted the uncomfortable fact. He preferred the hard truth to his dearest illusions. That is the heart of science.'
Old 7th August 2012, 08:22 PM   #35
chrisb is offline chrisb  Canada
very interesting indeed:
extract from text:
Instruments With Harmonics
Fig. Instrument SPL Harmonics Percentage (dB) Visible To of Power What Freq.? Above 20 kHz
1. Trumpet (Harmon mute) 96. >50 kHz 0.5
2. Trumpet (Harmon mute) 76. >80 " 2.
3. Trumpet (straight mute) 83. >85 " 0.7
4. French horn (bell up) 113. >90 " 0.03
5. French horn (mute) 99. >65 " 0.05
6. French horn 105. >55 " 0.1
7. Violin (double-stop) 87. >50 " 0.04
8. Violin (sul ponticello) 77. >35 " 0.02
9. Oboe 84. >40 " 0.01
Instruments Without Harmonics
Fig. Instrument SPL 10 dB Above Percentage (dB) Bkgnd. to of Power What Freq.? Above 20 kHz
10. Speech Sibilant 72. >40 kHz 1.7
11. Claves 104. >102 " 3.8
12. Rimshot 73. >90 " 6.
13. Crash Cymbal 108. >102 " 40.
14. Triangle 96. >90 " 1.
15. Keys jangling 71. >60 " 68.
16. Piano 111. >70 " 0.02 ]
note particularly #2, 7, 10, 15 & 16
... so, not as easy at it sounds, this letting go thing
Old 7th August 2012, 10:37 PM   #36
Banned
Yeah yeah. It is possible though that not being able to hear some these harmonics might actually sound better. Just because you can see a fat naked girl doesn't mean you want to see it. By the same token just because these harmonics are present (bloody obvious) doesn't necessarily mean they are pleasing to the ear. You might be better off not hearing them.
Old 7th August 2012, 11:10 PM   #37
'Got a file not found error but I should be doing this in the "BIB room" anyway. Elsewhere I have test tone cd but forget how high it goes-- that was the one Zilla recommended some time back transferred to a cd.
My bandwidth may be too tied up to try right now. But it raises a question I have had since my first kit build: is that rubbish heard in a tweeter only useful to anyone at all?
Old 8th August 2012, 12:58 AM   #38
Banned
Has anyone repeated the same sought of test with triangle, sawtooth, and trapezoidal (may as well add square wave too) waveforms?
It would be interesting to see what the ears response is to those waveforms compared to sine waves
Old 8th August 2012, 01:54 AM   #39
dirkwright's Avatar
None of these do it yourself tests are valid at all. You are deluding yourself if you think you are actually making any kind of scientific test with these online things. Go to an audiologist and get tested. Otherwise, you're just practicing wishful thinking.
Old 8th August 2012, 01:58 AM   #40
Banned
I am not even convinced that getting your hearing properly checked by an audiologist is that relevant either
Good online hearing test djn Full Range 1 21st April 2007 12:08 AM
Hearing Test jkeny Everything Else 8 25th February 2007 02:35 PM
What am I hearing? peace brainerd Solid State 9 2nd January 2006 06:15 PM
AKSA versus modified unit, a group hearing test inside my appartment destroyer X Solid State 37 4th October 2004 10:18 PM
DVD-A: What I am hearing? mpeg7 Digital Source 11 19th September 2002 12:08 PM
Copyright 1999-2017 diyAudio
