#181 |
actually, it measures almost exactly as it should.
(speed of sound) divided by the distance front driver edge to back driver edge closest distance 1129 / (39.4" / 12") = dip = 375hz = where driver front wave is 180 degrees out of phase from the back. There should be a peak an octave below that where driver front to back wave is 90 degrees out of phase thusly adding. 375hz / 2 = 187hz (yours is about 175hz, I'd call it good) So sucess and performs as it should. ![]() And how does it sound ????????????? Norman |
#182 |
Banned
Maceo Parker, Roots and Groove, Track 6, Pass the Peas. There is a drum solo half way through the track, accept the drummer is in your room. It is like someone hitting you with a cricket bat.
#183 |
Banned
I suppose I should also do it for the 10 Neodymium
#184 |
well done.
#185 |
Banned
To critically assess the sound I need to rebuild the baffle out of Birch or Bamboo ply.
The Audio Nirvana drivers are without any doubt a level above Seas. Last edited by Melon Head; 10th August 2012 at 09:43 AM. |
#186 |
Looking at the an10 plus the dual an15, once you get the 300hz hump and 1khz+ knocked down, that looks like a great project (but expensive). That's what most are looking for, a baffle about Jamo R909 sized, like the one you made. A few have made a similar full range plus 15's on 18" wide baffle (b200 with a pair of eminence alpha 15a drivers popular at audiocircle).
Ideally one can use different woofers rather than the pricy an15s for bass duty. Audio Nirvana states the an15 has a qts of .483 with 1mm xmax, 500hz downward, sensitivity looks to be 95db. The eminence delta 15a has qts .53 and 2.7mm Xmax and is 97db below 600hz 8ohm for $95. Or the eminence delta 15lfa has a qts .58 with 4.8mm xmax and 95db from 500hz down ($100). I'd look for something with a shorting ring, it help clean distortion up above 100hz, but they cost more also. Then again, eminence is pricey outside the US. Norman Last edited by norman bates; 10th August 2012 at 11:14 AM. |
#187 |
Banned
I haven't had a chance to use the B5 yet, because I have been busy doing measurements, but it should make things easy to dial in the right crossover point
#188 |
what's a b5 ?
#189 |
Banned
#190 |
This ain't much difference from having a box - with all those reflections from the wall so close.... ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
| "Box" design and bracing for open baffle woofer array | ryoshu | Multi-Way | 0 | 17th August 2008 06:07 PM |
| New Reference - SG-OB "Stargate Open Baffle" | Magnetar | Multi-Way | 67 | 17th July 2008 07:04 AM |
| design help needed: monopole 15" / 8" MTM open baffle with Manger | taloyd | Multi-Way | 26 | 26th January 2007 10:53 PM |
