Old 25th July 2012, 12:37 AM   #1
pbullblue's Avatar
Default I want to spend money!
I would like to purchase plans for the Valiant and the Silbury. I can't seem to make contact through the Woden Design website. Could someone help me out?
Thanks,
Bradley
Old 25th July 2012, 03:13 PM   #2
chrisb is offline chrisb  Canada
Thanks,
Bradley
e-mail Dave via Planet10 commercial site
Have you decided for sure on the driver? I assume you're aware the named enclosures follow the same basic topology, but are optimized for the Fostex FE126En ( Valiant) and Mark Audio Alpair10. (Silbury), the latter enclosure being larger in all three dimensions.
These drivers definitely each have their merits, but sounding alike the other is not among them
Having heard each of them in a range of enclosures (but not a direct comparison between the Valiant / Silbury), I can opine that provided you have the extra few watts and free space to accommodate the Alpair. it will not disappoint in terms of bass extension, soundstage and smoother upper mids than the Fostex.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 25th July 2012, 04:13 PM   #3
pbullblue's Avatar
I have both drivers. The Fostex in BK12s and the Alpairs are new.
Old 25th July 2012, 05:17 PM   #4
Scottmoose's Avatar
My apologies for the contact problems. I confess I often all but forget about the site, since it's not advertised and generally sits quietly in the background for people to find, or not find, as the case may be. Be that as it may though, the mail gets checked several times daily in conjunction with my other, unrelated email addresses, & I can confirm I haven't recieved anything, so something must be awry somewhere. I'll have to look into that. In the meantime, as Chris says, probably best to go through Dave.
Scott
Old 25th July 2012, 06:57 PM   #5
how to put this diplomatically (?) - the BK12 is cute enough little enclosure for what it is, but the same driver in the Valiant is transformed substantially
The Alpairs work very well in an MLTL or the MarKens ; I can only imagine / extrapolate how they'd perform in the Silbury - but I do have a vivid imagination
Old 25th July 2012, 10:31 PM   #6
pbullblue's Avatar
That's what i was thinking. Swapping my 126ens into a better enclosure. I am also considering the Kongo, for no other reason than I like the look of the front mouthed horns.
Old 26th July 2012, 04:33 PM   #7
I've a fair range of enclosures in this general "family"
Perhaps it's a personal / subjective thing, but between "smaller / single mouth" designs (BK12, Buschhorn MKII , Ron Clarke A126, Frugal Horn FH3) or larger dual mouth designs ( Harvey BVR, Aiko, Saburo, Maeshowe/Valiant, Victor), I've preferred the rear mouth designs every time.
Each format has its own room placement / or listening distance considerations, but when situated correctly, there's something about the bloom of lowest octaves and soundstage dimensions of the rear mouth designs that I find more appealing. No hard science about it I guess ....
Old 26th July 2012, 06:41 PM   #8
Scottmoose's Avatar
Not necessarily Chris. Assuming they are boundary loaded as designed / intended, the rear-mouth boxes are typically impedance matched to a lower frequency than the front-mouth boxes. In the case of, say, FH3 or Valiant, they're pretty much impedance matched down to cutoff. That's a big difference. Likewise the fact that the in-room power-response / interactions change with the different terminus locations. YMMV on that one.
If you wanted to try a 'little' experiment at some point, I could knock out a couple of very simple 1/2 space back horn variations for whatever drivers Dave has a surplus of, where the only difference would be the terminus location. Then you could back-to-back compare & see if your preference remains for the rear-firing terminus. My bet is it would, but possibly interesting. Possibly.
Old 26th July 2012, 07:06 PM   #9
I should have been more clear (random obfuscation is my middle name) - "no hard science" refers to the dearth of proven facts to buttress my sonic preferences (or sloth on my part to research and quote such as might exist in the literature)
or it could have been a crafty method to get someone else to make my point
I'm not sure
in our spare time before August 24th - sure why the hell not - Dave, fire up the CAD!
What did you spend on DIY this year? cuibono Everything Else 24 5th November 2009 12:07 AM
It's better to start with what one can afford, then spend what one doesn't have... SkinnyBoy Multi-Way 93 14th November 2003 11:33 AM
if you had $1000 to spend on two towers, what would you get? clipper10 Multi-Way 0 4th April 2003 05:01 AM
HIGH spEND audio HarryHaller Solid State 10 23rd February 2002 11:30 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
