Full range as Center channel - Page 2 - diyAudio
Old 19th July 2012, 05:35 AM   #11
Originally Posted by Einric View Post
I would figure a baffle board that is based on the "Golden Ratio" (Look it Up).
Place the driver on a position on the baffle that also adheres to the Golden Ratio ( this will help to minimize high frequency diffraction.
Mount one of those chambers behind the one driver; seal it with aquarium sealant and use screws to hold it in place.
Chamfer or roundover the edges of the baffle as much as you can (a rasp works well).
Build some kind of "kick stand" for the back of the baffle to hold it up.
I am also getting an offer on same pair...wanted to ask you how would they sound as in near field PC speakers powered with a D class amp...any idea?
still need the same way like adding an enclosure and adding a baffle on it..
V
Old 19th July 2012, 01:30 PM   #12
Einric is offline Einric  United States
Einric's Avatar
I'd say go for it!
They would be WAY better than any standard computer speakers available.
Don't expect great imaging & use a little toe in.
Old 20th July 2012, 12:19 AM   #13
Not bad....i just connected one driver as center channel and damn without enclosure the vocals are not bad...for 25$ a pair .... i think i will Biamp each signal ....this atleast in my room beat 300$ Linn center channel i had...
Old 20th July 2012, 01:33 PM   #14
Einric's Avatar
You will need to rig up some kind of rear enclosure to help protect the woofer from too much excursion.
Maybe a stiff rubbermaid small mixing bowl or something.
It will get even better in the highs when you build a baffle.
Full range center channel spartakus31 Full Range 3 1st May 2011 02:25 AM
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 03:07 PM
Center Channel Full Ranger? dvarner Full Range 12 25th October 2007 11:55 AM
Foam blocks between 2 Tang Band 3" full range on a small center channel The Paulinator Multi-Way 5 27th March 2003 05:04 AM
Copyright 1999-2017 diyAudio
