First build
First build
Old 17th July 2012, 06:43 PM   #1
xtreme2ya is offline xtreme2ya  Latvia
Default First build
Hey,
So i've decided to build a tube amp/speaker system to replace the my computer 2.1 speakers(Creative Inspire 2.1). The source is going to be my pc and the amp and speakers sitting on my desktop just like the current ones are right now(except for the sub obviously). While the amp's going to be a pp el84 one(haven't fully decided on the design itself), i am still undecided on the speakers and cabs. As a first build i have decided that i'll probably make 2 speakers with full range drivers(meaning that i'll make the cabs too). The drivers that i'm going to buy for dirt cheap are random soviet ones with most likely little info about them(although not necessarily). This build is experimental to get an idea of the sound. The branded higher quality speakers, crossover systems and other stuff is for the future. I should also add that i'll be listening to music on room levels, only rarely increasing it to hear it in another room.
Since the speakers are going to sit on my desktop, the maximum cab size is around 40x25x20cm(HxWxD). Now what driver diameter and cab type should i use? I think that a full range 3-5 inch driver with even the max dimensions i gave won't have enough bass, so i guess this is where a ported/vented design comes into play? Also i guess the cabs should be made from something that doesn't color the sound, contrary to guitar cabs, so plywood will do? What thickness should i use?
Thanks!
Old 18th July 2012, 02:39 AM   #2
GM is offline GM  United States
GM's Avatar
The 4" Markaudio CHR70 sims well in this size vented cab tuned to ~45 Hz using 13 mm Baltic Birch plywood, so a frame of reference.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
First buildHide this!Advertise here!
Build or not to build - $300-500 budget sasav Multi-Way 19 6th January 2012 02:27 PM
First Build! fizz Introductions 1 22nd October 2010 04:57 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
What I build rossco Multi-Way 9 6th August 2003 12:45 PM
Copyright ©1999-2017 diyAudio
