Old 16th July 2012, 05:39 PM   #1
JacobSijsma's Avatar
Default Line Array for +- 300 euro's ?
Can a full-range stereo setup with for example 8 drivers per side be done ? ( not counting amp, equalizer and enclosure ). And would it be cost effective ?
Old 16th July 2012, 09:10 PM   #2
18Hurts is offline 18Hurts  United States
The Tymphany TC9FD 3.5 inch full range seems to work well in arrays with EQ.
A guy on this forum used 25 of them per line array and reports excellent results. In the US, they run about 10 Euro each so your price will be different. I'd go for a minimum of 12 per side and 16 if you can swing it.
http://www.parts-express.com/pe/show...umber=264-1062
Old 27th August 2012, 03:04 PM   #3
use TG9FD instead, it's a better full range driver,
Old 28th August 2012, 07:33 AM   #4
Pnotus is offline Pnotus  Sweden
Hello!
For line array effect in near-field inhouse applications you are looking at a line with approx. 70% of total ceiling height.
Standard (Swedish) ceiling height, about 240 cm, gives you a line of approx 170 cm for line array effect.
If you are to be listening with some distance to speakers you should be OK with 3,5" drivers.
Closer distance maybe calls for smaller distance between centers, to not hear eventual cancellation related problems.
Regardless the Vifas both seem like very fine drivers. My own best at the moment is the small Faital Pro 3Fe20 model. Takes some power too which could be useful depending on how much EQ you want to put in.
Please excuse my English.
/pontus
Old 28th August 2012, 01:07 PM   #5
I spell like a hack - is there anyway I can edit my replies/comments?
Old 28th August 2012, 01:10 PM   #6
Pano is offline Pano  United States
Pano's Avatar
There is a 30 minute time limit on editing. I fixed your post.
how to combine Line array and transmission line together Jared Multi-Way 7 15th December 2012 01:20 PM
HT Line Array and T-Line Build tHEbLENNY Multi-Way 7 29th February 2012 04:58 PM
Help with converting sealed box line array loudspeaker to transmission line enclosure jb0194 Multi-Way 3 7th January 2012 05:08 AM
FS: Line Array Drivers - 84 drivers only $200.00! Magnetar Swap Meet 1 23rd August 2007 04:34 PM
Line array tweeter line - On left or right? dhenryp Multi-Way 4 9th March 2005 11:35 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
