I would like to run a rear firing tweeter with my open baffle 8 inch drivers.
so do I need to run these out of phase with fullrangers and still leave 1uf cap at positive terminal of tweeter even though the tweeter is actually getting a positive feed on the negative side. Thanks, Scott |
#2 |
Scott,
Heck if it's not too hard to change wires, try it both ways. btw, reverse switches are easy to make. |
#3 |
Tweeter is 8 ohm and fullrange driver is 5.9 ohm so wiring the tweeter out of phase
what impedance would my amp see. Last edited by bigaudioscotto; 16th July 2012 at 05:18 PM. |
#4 |
Your amp will see the FR's impedance mostly, since tweeter Z with the series cap will be high under ~20kHz. The FR driver likely has an impedance rise with frequency so will be of higher Z once the tweeter circuit's own Z starts to drop.
Tweeter polarity should not matter in this case since the waves are not even coincident, but try it both way and if you end-up prefering one leave it as is. IG |
#5 | |
Okay Thanks,
I just wanted to make sure that it was a safe load on the Amp. Scott Quote:
#6 |
Just out of interest, what 8" driver and super-tweeter are you using?
IG |
#7 |
Can I ask, why rear firing? I see this being discussed on the forum but have never understood it. I've never tried it either, so just wondering what you're trying to achieve here.
#8 |
The reason to rear fire is to keep the single point source firing at you
and the rear tweeter just adds some air to the top end without firing directly at you. it seems to have a more realistic soundstage that way to me. |
#9 |
| Rear-Firing Midrange to Help with Beaming? | goody75 | Multi-Way | 2 | 3rd February 2012 01:09 PM |
| Down-Firing or Rear Ports? | villeneuve | Subwoofers | 10 | 22nd April 2009 04:37 AM |
| what is the impact of having a rear firing port | peteS | Multi-Way | 8 | 4th March 2006 03:43 AM |
| Rear firing Seas 27 TDFC | LNeilB2 | Multi-Way | 9 | 9th August 2005 01:35 PM |
| rear firing tweeter - why? | bbaker6212 | Multi-Way | 5 | 25th September 2002 12:50 PM |
