SB acoustics SB12MNRX25-4 "full range" Build thread
Old 24th January 2013, 08:54 AM   #51
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
OK thanks Dave, That's different to what I'm seeing so there might be something wrong with my nearfield measurements still or there may be something else going on! Anyway regardless it sounds pretty good so I probably should stop obsessing
Blue is the unibox sim, red is the nearfield response with merged port response. The difference isn't huge but it is enough to bug me.
Upping the series resistance in the sim (second pic) to 2 ohms gets it a bit closer to the actual measured result, so maybe it is my dodgy alligator clips...
Anyway I won't get a chance to do anything more till the weekend most likely. I will report back if I work out what is going on!
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 24th January 2013, 09:03 AM   #52
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Isn't that bump expected from the measurment technique?
You see this all the time:
The rise in the upper bass is mainly an artifact of the nearfield measurement technique used below 300Hz
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th January 2013, 09:35 AM   #53
just another
wintermute's Avatar
Could be (time to dig out my d'appolito testing loudspeakers)!
Strangely my recollection is that my MTM sealed nearfield matched the sim pretty much exactly as did my 70L vented.
Tony.
Some of my photos
Old 24th January 2013, 12:44 PM   #54
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
Or that bump could be a box too big tuned too low.
Bob
Old 24th January 2013, 08:19 PM   #55
just another
wintermute's Avatar
Hi Bob, unlikely in this case I think. I deliberately made the volume smaller with higher tuning to get a more gentle rolloff with better transient response. Or at leas that was how it simmed
I suppose my T/S params might be an issue.
Tony.
Some of my photos
Old 24th January 2013, 09:01 PM   #56
just another
wintermute's Avatar
Bob, actually thinking about that don't you mean too small and too high? bigger and lower usually results in a droopy response... Leaving the volume the same (at 2.5L) and increasing the tuning to 110Hz in the sim gives me that rising effect.
I might try blocking off some of the port to lower the tuning frequency and see what happens. putting something down the middle would serve as a brace as well...
Tony.
Some of my photos
Old 24th January 2013, 10:01 PM   #57
5th element is offline 5th element  United Kingdom
5th element's Avatar
Any bump towards the low end tends to get thrown into the
Statement from stereophile. It's simply a diplomatic way not to have to really discuss baffle step losses, the chosen amount of compensation used and any wonky cabinet alignments.
In absolute terms, the true stereophile bump occurs because you're measuring nearfield, on a loudspeaker, that has baffle step compensation applied. As you're nearfield the loss doesn't occur and you see a hump as a result.
In terms of the small bump that you're getting Tony, it is most likely caused by the box alignment. The two things that I would mention here is that adding in the port can be tricky. As you measure everything nearfield, a small difference in measurement distance can grossly affect the measured SPL between the port and the driver, this can screw up how accurate the combined response is. The other thing to watch out for are any tone controls in the mic preamp, as even when set to zero they may not be.
The first is easy to fiddle with as you can simply alter the level of the port and see if you can get things to match up better. I tend to ignore measuring the port and rely on an impedance measurement to make sure that the port is tuned to the correct frequency.
The second problem you can only sort out by bypassing the controls internally via a bit of handywork. The behringer preamp mixers are popular but some don't have defeatable tone controls.
If you are concerned about the alignment then I'd go back to the simulator, keep all the box parameters the same, but remove the port (ie use a closed box). Check what the simulator predicts, then measure your box with the port plugged and compare the two.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 25th January 2013, 07:15 AM   #58
just another
wintermute's Avatar
Thanks 5th there is no BSC as yet. I like the suggestion of modelling sealed and measuring with the port blocked off
It's not a huge deal as they sound fine, but I like to get to a point where my sims correlate with what I do , and if they don't I like to get to the bottom of it! (read that as I'm overly obseesive )
When I was measuring my 70L BR boxes it wasn't matching and I spent a lot of time trying to work out why. In the end I'd dropped the mic at some point and damaged it, the LF response was affected. I tried a new mic and the sim matched the measured result
Tony.
Some of my photos
Old 26th January 2013, 11:52 AM   #59
just another
wintermute's Avatar
I had a bit more of a play today. I haven't tried sealing up the port yet. but I did try blocking roughly half of it off (in the middle) to get two separate ports. This dropped the box tuning to around 55hz (both in the sim and in actual measurements).
The FR flattened out a bit, though the difference is not that great. Interestingly it has a minimal effect on the transient response as well. It does however affect the curve up higher, though obviously with a NF measurement the higher frequencies can't really be trusted.
Apart from the fact that my port area halved (and there would be potentially more problems with port noise) This doesn't seem like a bad option.
I'm still rather stumped at how different the results are to the modeled response, but one thing is nice, the design is not too sensitive to box tuning!! I'm wondering if I really pushed the limits a bit far with how small a box I could build, and the sim gets inaccurate when pushing the boundaries this far.
Blue trace is with the lower 55Hz tuning, red is the original 70Hz. I Iike the rolloff of the lower tuned box better.
Tony.
Some of my photos
Old 31st January 2013, 09:32 AM   #60
just another
wintermute's Avatar
OK I think I have finally worked out what is going on re the sim not matching the reality. I will do some further tests to verify but maybe not till the weekend.
It suddenly dawned on me that I should try the sim with nothing other than a higher driver fs and see what happened. I chose 70hz instead of the 61Hz that I had measured. what do you know but the sim matches the measured response almost exactly!
The woofer I have been measuring with is the one that I did not do 12 hours of breakin on. I only did about 10 minutes of 45Hz on it before measuring the T/S params (which seemed to be enough and was the recommended method on the SB website). I should do the same before doing a nearfield measurement and see what happens. I suspect that the woofer returns to it's un-broken in behaviour when it has only had such a short breakin period!
Tony.
Some of my photos
SB acoustics SB12MNRX25-4 "full range" Build threadHide this!Advertise here!
Hemp Acoustics 8" Full Range Drivers $130 (Pair) Dilmonkey Swap Meet 7 5th May 2012 05:04 AM
First time Full Range Build tshaq Full Range 5 10th March 2012 07:00 PM
FS: Hemp Acoustics 8" Full Range Drivers $130 (Pair) Dilmonkey Swap Meet 1 29th February 2012 04:02 AM
Yet another 'help me choose a full range project' thread poynterama Full Range 21 27th October 2011 06:49 PM
Hi-Vi/Zaph/SB 3-way MTM build thread dmitriy167 Multi-Way 6 28th August 2009 03:17 PM
Copyright ©1999-2017 diyAudio
