SB acoustics SB12MNRX25-4 "full range" Build thread
Old 2nd February 2014, 10:33 AM   #91
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
OK so I had an 11uF Axon, a 1uF axon and an 8.2 ohm 10W resistor sitting around.
I took a quick and dirty measurement of the speaker in the study sitting on the daybed. Distance about 50cm and only about 5cm off the surface of the bed. Sort of like a mini ground plane measurement
I then put the RLC in series with the speaker and measured again. It is pretty much working as expected from the sim.
Pics attached of the test setup, and the comparison in holm with and without the notch. Finally I loaded the new measurement into speaker workshop and compared the simulated result (using the new measurement) with the actual measurement of the realised notch. I changed the values in SW to match what I now had.
Pretty good correlation, and I think shows the worth of speakerworkshop in prototyping notch filters. Interestingly if I leave the original values in SW (ie 22uH instead of 23uH and 7 ohms instead of 8.2 ohms) it is almost an exact match for the actual measurement...
1st pic, the (dodgy) measurement setup.
2nd pic, SW showing green actual no notch measurement, blue actual measurement with notch filter, black simulated response.
3rd pic the measurement in holm with and without the notch filter.
4th pic same as 2nd execpt with original vals of 22uH and 7 ohms in the sim.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 2nd February 2014, 08:15 PM   #92
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Tony, what do they look like off-axis? (as in on-axis measures are only really useful in the conrext of off-axis)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd February 2014, 01:35 AM   #93
just another
wintermute's Avatar
Good question Dave. I can't remember if I did any off axis measurement yet, I know I thought about it, but I suspect that I decided I'd do it next time (as my "gauge" for my speaker test stand had gone missing). It would be revealing to do a set with and without the notch filter.
I probably should wait till I've done something about the baffle step first though. edit2: BTW the dodgy measurements above are shown with 1/16th octave smoothing.
Tony.
Some of my photos
Last edited by wintermute; 3rd February 2014 at 01:39 AM. Reason: add comment about baffle step.
Old 4th March 2014, 05:19 PM   #94
nannoo is offline nannoo
Tony,
Looks like a great liitle speaker, I was checking out the driver wrt use in a 3 way, you mentioned you wanted to ***** its viability for use in a 3 way at the begining of the thread... can you share your thoughts following your experiences so far with the drive unit?
Old 4th March 2014, 08:26 PM   #95
just another
wintermute's Avatar
Hi Nannoo, I think that they would make an excellent mid driver in a three way (though not a high efficiency one as they are only 88.5db efficiency).
The tonality and clarity of them is very good. The main problem is going to be sensitivity, and baffle step I think. With only 88.5 db to start with if you drop say another 3db for baffle step compensation it is starting to get pretty low in the efficiency stakes. With a narrow baffle like here they start to drop off below about 1Khz. Obviously in the wider baffle of a three way that will be lower so it *may* not be too much of an issue.
I'll have to do some off axis measurements as well as Dave suggested. That will help with showing how high you could cross to the tweeter as well
Tony.
Some of my photos
Old 4th March 2014, 10:15 PM   #96
frugal-phile(tm)
planet10's Avatar
Best to deal with BS by XOing at or just below the BS frequency to more sensitive woofer(s) so that the full sensitivity of the mid can be used.
dave
SB acoustics SB12MNRX25-4 "full range" Build threadHide this!Advertise here!
Hemp Acoustics 8" Full Range Drivers $130 (Pair) Dilmonkey Swap Meet 7 5th May 2012 05:04 AM
First time Full Range Build tshaq Full Range 5 10th March 2012 07:00 PM
FS: Hemp Acoustics 8" Full Range Drivers $130 (Pair) Dilmonkey Swap Meet 1 29th February 2012 04:02 AM
Yet another 'help me choose a full range project' thread poynterama Full Range 21 27th October 2011 06:49 PM
Hi-Vi/Zaph/SB 3-way MTM build thread dmitriy167 Multi-Way 6 28th August 2009 03:17 PM
Copyright ©1999-2017 diyAudio
