Random enclosure idea?? - diyAudio
Old 11th July 2012, 07:17 PM   #1
lejaybo is offline lejaybo  United Kingdom
Default Random enclosure idea??
Hello peeps,
been looking into making some ikea bowl spheres as a simple full range speakers
but....................
was wondering what would
BLANDA MATT Serving bowl - 12 cm - IKEA
on top of this
SEKIN Serving bowl - IKEA
would this work good? or is it bad for internal waves and such
Old 13th July 2012, 08:49 PM   #2
tvrgeek is offline tvrgeek  United States
Round can be good. Might check out what US Enclosures says about round. You will need some kind of way to dampen it.
Old 13th July 2012, 10:32 PM   #3
FullRangeMan's Avatar
The best enclousure is the sphere, second is the tube/cylinder, called as Bazooka in automotive sound.
Square/rectangular boxes are the worst sound, a compromise, to favor the convenient use of flat wood/MDF slabs.
A pity this shell is small, What kind of wood is it??
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 13th July 2012, 11:44 PM   #4
Full sphere is smoothest. Cylinder is only good if used on end. Mounting the driver like a Bazooka is horrible. See Olson. Actually, search on "Olson diffraction" and look at the various sites. Everyone sites his original paper because he did it correct the first time and no one has anything much new to say!
Boxes can be made to behave very well with big round over bits or clever application of 1/2 inch thick felt.
Old 14th July 2012, 12:03 AM   #5
HI,
I fail to understand. What you mean say with ''used on end'' and ''Mounting the driver like a Bazooka''??
Old 14th July 2012, 01:05 AM   #6
frugal-phile(tm)
planet10's Avatar
Sphere is the best shape wrt 2pi to 4pi transition ripple of the shapes Olson tested (ie looking only at the outside, the inside is a bad shape). Teardrop (as per B&W) is better and doesn't have the same internal standing wave issues that a sphere has. Driver mounted on the end of a cylinder is bad, driver mounted on curve of cyclinder is much better but not as good as rectangular box with big champhers.
Page 23 Olson
OP's suggestion of half-sphere on truncated cone is a good one, this is closer to teardrop (add a duncecap on the back-side to finish it off). And on top of that you save 9 per speaker.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th July 2012, 01:09 AM   #7
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
The sphere is NOT the best! In order of worst to best..1) Sphere 2) cube....3) all others 4) A calculated best Acoustic ratio 1.2599-1- .7937.
Think about it... the sphere will reflect internal waves from a point source to the walls (At equal distances) & all arrive back to the same place, in phase, equal intensity....This will compound & concentrate the back-wave...Same somewhat with the cube. An acoustic ratio breaks up these frequencies by a mathmatically derived proportion.
__________________________________________________ ___Rick.........
Old 14th July 2012, 01:10 AM   #8
frugal-phile(tm)
planet10's Avatar
One potential complication: the cone needs to be the same diameter as the bowl, no dimensions are given.
dave
Old 14th July 2012, 01:12 AM   #9
Ron E is offline Ron E  United States
Ron E's Avatar
Beware anyone who cites Olson on diffraction, especially when they mention US Enclosures in the same breath...YMMV.
Olson used a point source (2" diameter) mounted in the center of his ~24" baffles. This overstates the effect of diffraction in most cases.
If you move a piston in the end of a cylinder slightly off-center, diffraction performance becomes surprisingly good, as does the off-center performance on many of his examples. When a source takes up a large percent of the baffle, shape becomes rather unimportant.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 14th July 2012, 01:16 AM   #10
frugal-phile(tm)
planet10's Avatar
Page 22:
dave
Is this a good or bad idea (too small enclosure for a woofer) critofur Multi-Way 9 23rd March 2008 06:59 PM
Is distortion random ? Bernhard Solid State 46 30th December 2003 01:59 AM
Interesting enclosure idea: GrahamnDodder Chip Amps 1 21st October 2003 08:23 PM
GC enclosure idea and question: GrahamnDodder Chip Amps 5 28th July 2003 12:36 AM
Enclosure Idea, but a few questions. Milzie Multi-Way 2 4th December 2002 05:56 PM
Copyright 1999-2017 diyAudio
