Random enclosure idea??
Old 14th July 2012, 01:53 AM   #11
FullRangeMan is offline FullRangeMan  Brazil
FullRangeMan's Avatar
Originally Posted by Richard Ellis View Post
The sphere is NOT the best! In order of worst to best..1) Sphere 2) cube....3) all others 4) A calculated best Acoustic ratio 1.2599-1- .7937.
Think about it... the sphere will reflect internal waves from a point source to the walls (At equal distances) & all arrive back to the same place, in phase, equal intensity....This will compound & concentrate the back-wave...Same somewhat with the cube. An acoustic ratio breaks up these frequencies by a mathmatically derived proportion.
__________________________________________________ ___Rick.........
The sphere enclousure is the best sound why it had no flat walls inside to amplify the resonances, which funnel down.
I fell you would say rectangular Golden Ratio box is good, but these proportions you mention are strange.
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 14th July 2012, 09:53 AM   #12
lejaybo is offline lejaybo  United Kingdom
Originally Posted by planet10 View Post
One potential complication: the cone needs to be the same diameter as the bowl, no dimensions are given.
dave
hi,
so the hemi-sphere bowl is Dia 28cm with a 13cm height
and the cone shape bowl is Dia 28cm with 13cm height
my first thoughts of using these was to make a crude B&W'esc teardrop cabinet
going to buy some this weekend so i can measure the internals
Old 14th July 2012, 10:35 AM   #13
ODougbo is offline ODougbo  United States
Default Cylinder Subs
Few years back I found a huge PVC drain pipe, 15" ID 1/2" wall (still have 4' left). I made several BR subs with 8" and 12" woofers.
They worked okay, I didn't see any advantage over a rectangle box. I had some pics, but must have delated them.
I would add if sphere is the ideal speaker inclosure, there would be 100s of them available in stores, web, etc.
Old 14th July 2012, 10:48 AM   #14
tvrgeek is offline tvrgeek  United States
The sphere is ideal only in how it manages baffle step and diffraction. We can beat boxes into submission and they pass the WAF easier. There are spherical speakers on the market.
This is pretty simple physics. Just go read Olson's paper. It has ONLY to do with diffraction and baffle step. No magic, golden, Fib sequence, smoke and mirrors. Like I said before, his original work stands so well, no one has needed to revisit the subject. Just read it.
BTW, a sphere with a wad of damping in the center works exceedingly well. Also note that internal reflections are no where near as important as the external problems Olson addresses. Not unimportant, just not as.
Old 14th July 2012, 04:36 PM   #15
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The paper is a book. Acoustics.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th July 2012, 04:59 PM   #16
TheBaronGroog is offline TheBaronGroog  United Kingdom
Here's the equation you need to work out what freq your spheres will work down to in terms of removing defraction issues:
required sphere radius = 13500 / lowest frequency / 2 / pi
Old 14th July 2012, 05:13 PM   #17
frugal-phile(tm)
planet10's Avatar
Mr Groog's formula spits out inches
dave
Old 14th July 2012, 05:16 PM   #18
Ron E is offline Ron E  United States
Ron E's Avatar
Bews and Hawksford, Lipshitz and Vanderkooy, Juha Backman, just a few who have published analytical papers in the JAES since Olson's rather crude empirical work.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 14th July 2012, 08:17 PM   #19
I went through all 4 volumes. You know, his "crude" work has everything this thread needs except getting a few people to actually read it. If you can mention a specific paper that adds to this conversation, let me know and I will revisit it.
So for those too lazy to do a simple search:
Diffraction Information & Graphs
Old 14th July 2012, 08:36 PM   #20
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
OK......howbout a box for your low-end & a sphere for your mids???
__________________________________________________ __Rick....
Random enclosure idea??Hide this!Advertise here!
Is this a good or bad idea (too small enclosure for a woofer) critofur Multi-Way 9 23rd March 2008 06:59 PM
Is distortion random ? Bernhard Solid State 46 30th December 2003 01:59 AM
Interesting enclosure idea: GrahamnDodder Chip Amps 1 21st October 2003 08:23 PM
GC enclosure idea and question: GrahamnDodder Chip Amps 5 28th July 2003 12:36 AM
Enclosure Idea, but a few questions. Milzie Multi-Way 2 4th December 2002 05:56 PM
