Old 5th July 2012, 12:36 PM   #1
Default Which 5-5.25" for 5-7L closed or bass reflex enclosure?
Hello friends, I'm new here and hope I've chosen the right forum. Until now I just used german forums and didn't speak english often. I hope you will understand
I'm searching for a good 5.25" fullrange-driver (could be a coaxial speaker too) for using it in a 5-7l closed or bass reflex enclosure on the dashboard of a Volkswagen New Beetle. A 6.5" driver could be possible too, but then the magnet and the basket have to be very small.
I don't want to pay more than 150$ per piece, less would be better
At moment I prefer the Tang Band W5-1611 but I'm open for other options.
Old 5th July 2012, 08:22 PM   #2
Nanook is offline Nanook  Canada
Nanook's Avatar
Default you might try...
...the car audio forum (look further down on the forums page).
stew -"A sane man in an insane world appears insane."
Old 5th July 2012, 08:35 PM   #3
In german forums I have made the experience, that the car audio freaks aren't informed as good as the home audio freaks about drivers like this, but I will check it. Thx
Old 5th July 2012, 09:28 PM   #4
chrisb is offline chrisb  Canada
I could be worrying over nothing, but my intuition is that the car audio environment is not particularly hospitable to the type of wide-band or even co-ax drivers that us home audio/video DIY freaks generally play around with.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 5th July 2012, 09:38 PM   #5
Why do you think so? Because of the temperatures and the humidity? Or based on the near reflecting areas?
Until now I've get really good results with drivers like KEF, Vifa or Tang Band.
Old 14th July 2012, 01:45 PM   #6
no answers?
Old 14th July 2012, 04:10 PM   #7
frugal-phile(tm)
planet10's Avatar
The TB 1611 would be good (waterproof as mondo points out). It is a good sounding driver (althou they do have a bit of plasticy colouration, probably not a big issue in a noisy car environment). The biggest issue with it is the phase plug and open voice coil. Especially if it is facng up junk is gonna get in there.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th July 2012, 04:12 PM   #8
Moderation Team's Avatar
Dup thread in car audio closed, only 1 thread allowed, and this is the only one with responses,
Old 14th July 2012, 04:13 PM   #9
frugal-phile(tm)
planet10's Avatar
The only other driver i can think of off the top would be the mark audio CHR-70.
dave
Old 14th July 2012, 09:51 PM   #10
Thank you. The Mark Audio I know very good, but the the relationship of diameter and effective piston area isn't really good. I want to have a really dynamic until 100-150Hz and in a noisy car I think the mark audio will be limited very quick.
That was the reason why I have separated out the Fostex FE 126 EN and the Fountek FW146. Someone recommended the Cube Audio F 155 to me but I can't find some Info's.
6L Sealed Enclosure - 6.5" Woofers! Veloxy Multi-Way 37 14th November 2012 04:10 AM
6,5" to 7" midwoofer for sealed enclosure martinbls Multi-Way 93 26th September 2012 11:22 AM
Zaph ZA5.2 Ported/Vented 7L (.25 cf) Design pirate121 Multi-Way 9 11th September 2010 03:08 AM
Need help with 5.25" driver for sealed enclosure MrDragon1 Full Range 11 1st March 2010 12:18 AM
15" woofer in sealed enclosure KCCT82 Multi-Way 23 18th January 2008 03:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
