A12.2P Super Pencil Build......
Old 4th July 2012, 03:22 AM   #1
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Default A12.2P Super Pencil Build......
As promised, here are a few pics of my new Super Pencils. These are all low rez, as Chris was worried that the brad nail holes would show. Material is 15mm Baltic Birch, with an extra 9mm added to the front baffle. There is about 10" of Ultratouch at the top of each box, and approx. 280 grams of Polyfil. This combination sounds pretty good, but there will definitely be some experimentation down the road. I have material to raise the speakers up a few inches, so that's next on the list.
So, a big thanks goes out to Chrisb for cutting all the material, which is a LOT of work, even for a fairly straight forward design. Also, for letting me help with the assembly. These boxes went together very quickly. On my own, they would have taken much more time to assemble.
Also, thanks to Dave for providing the drivers and the drawing, Scott for the box design, and of course Mark for designing and producing such a lovely driver.
jeff
Old 4th July 2012, 03:33 AM   #2
Bigun is offline Bigun  Canada
Bigun's Avatar
very nice cabinetry - the joints and cutting are way better than I have achieved with my builds.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 4th July 2012, 03:39 AM   #3
doorman is offline doorman  Canada
doorman's Avatar
Chris has done a few pairs!
Don
Old 4th July 2012, 03:46 AM   #4
vinylkid58's Avatar
And it shows. He is also very efficient.
jeff
Old 4th July 2012, 03:47 AM   #5
ejfud is offline ejfud  United States
ejfud's Avatar
I wish I lived near Chris!
Nice job gentlemen.
Gary
One good driver is all I need.
Old 4th July 2012, 05:20 AM   #6
zman01 is offline zman01  Bangladesh
Looking great Jeff, and nice work indeed - also probably the first build of its kind!
I like the bracing too - nicely done and holding up the fluff very nicely.
Your dog is sleeping/resting peacefully in between the pair, so must have been good stuff playing?
Aside to Dave and Chris,
Choice of 15mm BB vs 18mm - extending the stiff and lighter philosophy?
- Zia
Old 4th July 2012, 04:44 PM   #7
chrisb is online now chrisb
- Zia
more a case of "we had lots on hand" - several years ago we settled on using 18mm (or sometimes more) for baffles, and 15mm for the remainder of most enclosures. It would make for an interesting experiment to build identical pairs with different thicknesses, but I just can't seem to get excited about trying that
Note that even 18mm is a bit thin for the baffles if rebating for flush mounting of the 12Ps - even allowing for minimal compression of gasket, the total "Z"=10mm, so I laminated 15+9 - much more than that and the relief of rear side of opening would need be fairly severe.
kinda burnt out - taking a break
Old 4th July 2012, 05:16 PM   #8
KyleinCowichan is offline KyleinCowichan  Canada
KyleinCowichan's Avatar
Looking great! Will we get to have a listen at DIYFest?
Kyle
Old 4th July 2012, 05:36 PM   #9
Chris,
Do you extend the lamination all the through the length of the baffle, or pad up only the area around the driver mounting?
Old 4th July 2012, 05:53 PM   #10
Chris,
I've done both at different times, but in this case ran full length as it simplified both the rabbets in side panels for insetting the baffle*, as well as eliminated the need to notch the front to back holey brace - which is already a fiddly enough part to machine & fit.
*Jeff or my photos don't show the little fill blocks glued in to the rabbeted shoulder of side panels that would be otherwise exposed at the front terminus opening. Not the most elegant solution, but certainly quick
A12.2P Super Pencil Build......Hide this!Advertise here!
Super Pensil Build with Pics zman01 Planet 10 hifi 38 9th July 2011 06:23 AM
Super Pensil 12 Build zman01 Planet 10 hifi 3 15th April 2011 02:15 AM
DC supply for Jensen A12 field coil driver korneluk Full Range 1 21st March 2008 07:23 PM
Jensen A12 OB + Altec 802-8D Horn Project nullspace Multi-Way 8 30th January 2008 03:02 PM
Jensen A12/F12 field coil drivers T/S parameters? mefistofelez Multi-Way 0 27th October 2006 04:23 AM
