BLH compression chamber.
Old 6th July 2012, 11:23 PM   #21
bear is offline bear
expert in tautology
bear's Avatar
Yours is lower Q?
Going by recent memory.
- why is the Voxativ a criteria?
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 6th July 2012, 11:24 PM   #22
expert in tautology
bear's Avatar
Originally Posted by Scottmoose View Post
That's what GM & I have been doing (more or less). From my POV (I belive Greg has a similar take) I tend to use the term 'horn' for any pipe that expands toward the terminus, since it possesses some degree of 1/2 wave behaviour. It may or may not be impedance matched down to F0 (the 1/4 wave cutoff determined by axial length & taper). Ideally, it would be, but that is not always practical for obvious reasons.
Sorry not sure what you are saying?
1/2 wave behavior is resonance?
Afaik traditional horns are not designed to be resonant.
_-_-bear
_-_-bear
Old 7th July 2012, 12:15 AM   #23
GM is offline GM  United States
GM's Avatar
If it's not resonating, it's not making any sound: Resonances of closed air columns
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 7th July 2012, 12:40 AM   #24
expert in tautology
bear's Avatar
except that horns are intended as impedance transformation devices, not organ pipes, or woodwinds.
_-_-bear
Old 7th July 2012, 12:41 AM   #25
expert in tautology
bear's Avatar
anyhow hm's product, on his webpages:
"Some things to note about this design: There is a forward-firing and rear-firing driver. Depending on choices of the builder, the rear driver can be a woofer or a second fullrange driver. -- The two drivers drive two different horns, of different length and expansion.
The idea is that the horns have different peaks and dips and fill in each other's weak points. --
The inner horn rests on the outer section via a panel of soft fiberboard, which decouples it.
Also notice how the horn mouth is wrapped around the entire enclosure. It is relatively large,
yet the enclosure the driver sees is relatively small.
Finally, I think it is a beautifully proportioned horn, which draws much less attention to itself
than some of Horst's other designs.
To his credit, and downfall, of most of his designs. He is criticized for strange and peaky/dippy response graphs, but I think they mostly show how tough it is to measure a smooth response in a room. He offers several measurements, from several drivers, measured in several positions. At the very least, the horn does bass. At best, it has response below 30 Hz."
_-_-bear
_-_-bear
Old 7th July 2012, 02:05 AM   #26
GM's Avatar
Ok, what is happening in the horn during this impedance transformation for it to make sound?
GM
Old 7th July 2012, 06:40 AM   #27
hm is offline hm  Europe
hm's Avatar
Default - why is the Voxativ a criteria?
speaker of the year, expensive, "same" measurement circumstances.
thanks for understanding
http://www.hm-moreart.de
Old 11th July 2012, 07:59 PM   #28
hm's Avatar
may this helps for understanding horns:
Horns
Old 11th July 2012, 08:53 PM   #29
jacozz is online now jacozz  Sweden
Horn... Transmission-line.... bla bla bla....
But, How does it sound? What are the sonic differences?
That is really all I care about.
This ****-fighting is really tiresome.
Old 11th July 2012, 09:26 PM   #30
GM's Avatar
In theory, the horn has a bit more gain in the mechanical XO BW, so generally doesn't need any BSC, making for a bit better mid-band dynamics and maybe fewer components in the signal's path-length.
The reality though in how they sound is in how each person perceives the differences, so it's up to the individual to do whatever it takes to find out which type of speaker alignment sounds best overall to them.
GM
BLH compression chamber.Hide this!Advertise here!
Question About The Effects of Damping Materials In the Compression Chamber of a BLH mister pig Full Range 13 25th January 2010 04:28 AM
So, what exactly does a compression chamber do?? NV&H Full Range 2 5th February 2006 12:40 AM
front loaded bass horn without rear compression chamber? paulspencer Subwoofers 9 28th October 2005 04:53 PM
Compression Chamber Size mrlots2do Full Range 29 17th August 2005 06:02 PM
Why, horn, compression chamber? tade Subwoofers 8 28th April 2005 06:04 AM
