Hi all
After spending some time getting to grips with DIY electronics it's now time to finally look at building some speakers. I've decided on the Lotus^2, with one front and one side firing driver. I have the drivers already (BB4-AL variant of CHR-70), it's not a complex build, and they aren't going to annoy the lady of the house.
This will essentially be a "training" build for me. I've read all the threads I could find about the Lotuses, but I'd be grateful for some advice on the following:
1. The original plans are for 19mm material. We only get 18 and 25mm here, so I've redrawn plans for both thicknesses. The question is this: is there any real benefit from using 25 instead of 18mm? The cost is higher, but if the benefits are worth it I'm happy to spend the money.
2. Any advice on lining / stuffing? I've got a good amount of both Sonofil fluff as well as Visaton damping material. Which of these should I use? Or is there something else I should consider? By the time the side panels are on I'll probably have lost a couple fingers to the table saw, so I'd prefer to avoid taking them off again to mess about with the guts if at all possible... . I looked at the following pics:
http://www.diyaudio.com/forums/full...chr-70-application-thread-29.html#post1919397
http://www.diyaudio.com/forums/full...-build-listening-impressions.html#post2761168
These look to be about the right amount of stuffing, yes? Should it be applied to the remaining side panel as well?
3. Should I place a cap inline with the side-mounted driver? Motosapien recommended 68uF to tame the highs - has anyone else tried this? The BB4-AL variant should have a slightly smoother top end.
4. and last, what to do with the bottom deflector? Should I stick with the stepped approach, or alternatively go with a flat panel and load the void behind it with sand? What kind if dispersion characteristics will each offer?
I'm a total n00b when it comes to speakers. Thank you very much !
Tachyon666,
Good to see a reference to my build thread in your post.
I'll try to answer a few of your queries - if I am wrong, the more learned and experienced folks can always correct me!
1. 25mm vs 18mm ply - 25 mm is probably too much, and too thick cabinet walls may not be ideal. So, 18mm will be good enough for the build.
2. Lining the desugnated areas inside the The Lotus^2 should be good enough, no need for stuffing. The lining material recommended is ~3/4" wool/receycled denim type felt material. IIRC fibreglass can also be used, but poses some health hazards - so I would not advise.
3. My guess is that cap will not be required for BB4.AL
4. the stepped deflector will add some mass to the bottom - in my expereince not required. But if you have small kids or pets, better to make the base as shown in the plans for stability.
Not to detract you from the Lotus^2 build, but there's another design for twin CHR-70/BB4.AL that grabbed my attention - the Woden Mercia - a large MLTL. Recently came across a thread where a forum member built a pair for HT duty and was very happy.
- Zia
- Zia
Yup, I took some inspiration from your buildGood to see a reference to my build thread in your post
Good to hear! Will save me some cash...18mm will be good enough for the build.
Hmm... the stuff I have is lightweight poly fibre. Possibly not dense enough?The lining material recommended is ~3/4" wool/receycled denim type felt material.
No kids or pets, but I prefer a lower centre of gravity for safety's sake. If I go with the flat panel I'll fill behind it with sand or lead shot.the stepped deflector will add some mass to the bottom
The Mercia seems pretty awesome, but I think the aesthetics of the Lotus will mean less hassle from the girlfriend . Plus I hate cutting circles - straight lines are fine, but circles just remind me of how much I suck at woodworking...the Woden Mercia - a large MLTL
For lining if you are refering to "poly batting", I have found that these do not have the same effect as denim/cotton felt material. Another option is jute carpet underlay - 2-3 layers of 6 mm stuff should do the job.
Yep, agree - among the big boxes, probably the Lotus^2 scores highest WAF wise with the narrow baffle and slanting top.
BTW, if you are intimidated by the holey bracing in the Mercia drawing, don't be - simpler bracing can be used, even if it doesn't result in the same degree of stiffness. If you ignore the bracing, Mercia will have fewer pieces and easier to build.
Before I forget, make sure you do a rebate for your drivers so they are flush-mount on the baffle, and you also need to do a chamfer/round over on the inside of the hole.
The circles in the braces are typically cut w/ a hole saw. Not so bad.
The specs on the CHRs didn't change much.
dave
I read that the third Gen chr70 dosen't go as lowas the second Gen.
- Full Range
- Lotus^2 build advice
