My New Audio Nirvana Drivers - Page 86 - diyAudio
Old 22nd August 2012, 02:16 AM   #851
Ginge is offline Ginge  Australia
MH,
Thanks. Yes chased up the thread on PHY style baffe. It is tall. Thinking myself now of using my AN 12's Alnico at FR and adding some cast 15 bass assist in OB or FAST.
How are you finding the B5. Anyone using pure music and exasound dac for crossover control.
Cheers
Old 22nd August 2012, 03:08 AM   #852
Banned
Originally Posted by GM View Post
Blocking off the baffle and cutting a new driver hole at ~20% down and locating the ports right at the bottom should improve performance somewhat. This should yield a small amount of TL action, lowering the vent's tuning slightly plus their close proximity to the bottom plate will further lower it due to their close proximity to the bottom plate. Just slide the tubes in part way and use blu-tac or similar to seal them in case they need an even lower tuning to flatten the response out.
GM
Here is a photo of the baffle. I will first try properly sealing tne ports with blutac
Old 22nd August 2012, 03:20 AM   #853
Banned
aah crap wrong box. LMAO . Too many boxes haha
Old 22nd August 2012, 04:20 AM   #854
Banned
Here is the correct picture. Hehe
I am not sure whether moving the ports another inch lower will be that effective
Old 22nd August 2012, 08:12 AM   #855
Banned
Originally Posted by Ginge View Post
MH,
Cheers
The baffle does not necessarily need to be that tall, but you want to avoid putting the driver close to the top edge. I am going to see how much I can shrink the height down before it starts having a negative effect. My gut says 1.2m to 1.4m for a fast setup, but it really depends on how high you want to put your driver on the baffle. As a rough guess you want about 40cm or more in baffle height above the top driver
Old 22nd August 2012, 01:57 PM   #856
tsiros is offline tsiros  Greece
tsiros's Avatar
Send a message via MSN to tsiros Send a message via Skype™ to tsiros
ah i see you went with the wide version of the 5.6
i went with the wide version too
the speaker looks imposing, though. dammit, wish i could cash up that much
the 12 CFs cost me $380 :/
Old 22nd August 2012, 02:04 PM   #857
GM is offline GM  United States
GM's Avatar
Interesting, the couple of A-N cabs I've seen had the driver near the middle with the ports directly underneath in the classical BR layout that causes a big dip in the mid-bass if not in a golden or acoustical ratio cab.
The cab shown should be much smoother/flatter once damped and tuned to Fs and even more so if tuned to ~23 Hz.
Then again, if there's any air leaks, the cab's tuning will be much higher than it should be and cause the sort of response you're getting.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 22nd August 2012, 09:21 PM   #858
Banned
Thanks for all the suggestions.
I will try sealing the ports first then remeasure
Old 22nd August 2012, 09:47 PM   #859
Banned
I didn't have a choice, the 15s are too wide for the narrow version.
I aggonised quite a bit over purchasing these but when I really weighed everything up they are a true bargain. On the last speaker-build I spent over $300 dollars just on crossover components.
This time around I wanted to build something high efficiency so my options were more limited.
The amount of money I have spent on building amps is probably in the 1000s of dollars, and the cost of a good cd player, blah blah etc, I thought I really owed it to myself not to foolishly try and save money and then end up paying more.
Initially I was going to get a pair of GPA 604-8H III at around $2000 because I heard a pair and really liked them, then I had long discussions with David Dicks and decided to give him a chance, and I am glad I did, because I like these more than the GPA coaxial speakers.
Old 22nd August 2012, 10:28 PM   #860
BudP is offline BudP  United States
BudP's Avatar
And soon enough, a laptop turned into a music server, with attendant worries about USB asynchronous output, just because the quality of sound from such a thing is so far superior to anyone's CD player....
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Audio Nirvana Super 8 Drivers for Sale cascadeguy Swap Meet 12 1st October 2012 03:08 PM
Audio Nirvana drivers MagnumOpus Full Range 54 7th May 2011 04:17 AM
new project based on audio nirvana 12in drivers Jamh Full Range 89 1st August 2008 10:21 PM
Audio Nirvana Drivers drwho Full Range 15 20th December 2007 05:33 PM
Copyright 1999-2017 diyAudio
