#501 | |
Max |
#502 |
tubemax
what marker did you use? is it permament? alcohol free? What estimated milligram/mm^2 is it? did you measure the drop in Fs of the drivers? |
#503 | |
#504 |
Looking here, the rise past 1khz is quite high, 5 or 7db even. Then mix in a 1' wide box with no baffle step. Seems most 8" rise 1-4khz.
But I am impressed that an eq circuit is present. Add baffle step and nice. New 8" full range speaker from L CAO My only concern would be a tiny bit of highs bouncing around by the dust cap. But way better than a whizzer. But a whizzer would help off axis response from 2-4khz. Nelson Liked it. If I was in the market for an 8", I'd go for it. Norman |
#505 | |
THis comment a couple of days ago took them off the radar for me.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#506 | |
Regardless, the bottom line for me is that based on what's been presented combined with the driver's published data, IME the drivers aren't defective, just typical whizzer enhanced ones and tsiros will have better luck dealing with whizzer related resonances down low than only up high assuming he's not hearing a signal chain related noise. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#507 |
As Michael said the drivers he tested were brand new. With my own AN12's there was very noticeable improvements at the 200-300 hour mark. Before that point I did find the speakers to sound more strained at upper volume levels. Somewhere along that 200 - 300 hour period everything improved and the upper volume levels which I very much enjoy started to capture some of the realism of the real event. This was very noticeable with live concert grand piano recordings and vocals. I do not think this is merely a matter of me getting used to them as I move daily from my home to office with different but equally high caliber systems. Anyway the point is that whether the cracking noise was related to whizzer or spider or who knows what, the break in time really does improve the performance. I would think the same will be true for the AN15's so Melon you may be in for a real treat after the 200 hour mark so keep us posted.
#508 |
I noticed my neighbors bass guitar speakers. Some were burned in, some wern't. The burned in cones almost had a fuzz on them, you could see it. I assume that would be some of the paper fibers being "scratched" out ? So only what is left is more flexible ?
Norman |
#509 |
are you sure the fuzz wasn't dust or just aging? I don't think physical appearance changes with driver burn-in?
#510 |
Banned
| Audio Nirvana Super 8 Drivers for Sale | cascadeguy | Swap Meet | 12 | 1st October 2012 03:08 PM |
| Audio Nirvana drivers | MagnumOpus | Full Range | 54 | 7th May 2011 04:17 AM |
| new project based on audio nirvana 12in drivers | Jamh | Full Range | 89 | 1st August 2008 10:21 PM |
| Audio Nirvana Drivers | drwho | Full Range | 15 | 20th December 2007 05:33 PM |
