FE127e replacement - diyAudio
Old 21st June 2012, 02:34 PM   #1
Default FE127e replacement
Some years ago, I had my carpenter build (for my friend) ML-TQWT enclosures, much like this one.
Can't find the exact plans I used, but they also came with schematics for some kind of equalization/BSC circuit, which we had, built into the binding posts.
Now, both the drivers are torn and battered (damn the movers!). Recommended drop in replacement drivers, now that the Fe127e is no longer available?
I've spent the last couple of hours poking around here for a definitive solution, but I'm not sure I'm getting anywhere... The CSS EL70 seems to come up as a good replacement?
I realize that the lower sensitivity means that the t-amp which was being used is no longer an option... anyway its busted and we'll have to look for a suitable amp once we have found the driver. Anything else I should worry about?
Thanks for inputs...
Old 21st June 2012, 05:14 PM   #2
chrisb is offline chrisb  Canada
Closest drop-in replacement for the FE127E would likely be the FF125WK - exact same basket / cutout pattern, and very similar sensitivity.
The CSS EL70 would be a great candidate for a metronome as well - I'm not sure how many may have been built, but the calculated dimensions are found here
The Metronome
You'll note quite substantial differences between dimensions for the FE127E vs EL70 - as much as I like both drivers, I'd be inclined towards the FF125Wk for this application.
on hiatus
Old 21st June 2012, 05:26 PM   #3
Jim Shearer's Avatar
And while you are at it, why not order the Fostex grills to protect against accidents and curious fingers? As they say, "I saw the sign", and have added grills to all my builds now. The change in sound is minor compared with what can happen otherwise...
Cheers, Jim
A day without music is like a day without food.
Old 21st June 2012, 08:27 PM   #4
Cheers, Jim
agreed - and if you really think you can hear the difference, the metal Fostex grilles could probably be fitted with little neo magnets for quick removal by "trained specialists"
on hiatus
Old 21st June 2012, 09:19 PM   #5
Bob Brines's Avatar
Indeed. I did this with the 6" grills. The mounting holes are 6mm. You can force 1/4" magnets into them. They will hold to the driver mounting screws.
Bob
Old 21st June 2012, 10:26 PM   #6
Bigun is offline Bigun  Canada
Bigun's Avatar
I have a pair of FE127's that are sitting unused that I was planning to sell on. They were installed in boxes but not used so I took them out again. PM me if interested.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 22nd June 2012, 04:55 PM   #7
note potential destination - freight charges from Canada could well exceed cost of new drivers sourced more locally?
on hiatus
Old 4th July 2012, 08:06 AM   #8
I've been modelling both the FE127 and the FF125WK in the metronome. The metronome is very forgiving of the driver and the FF125WK will go in there. Volume is on the large side and the port could do with a slight lengthening.
Did you seal the inside? (I never do, some others always do). If not then you could cut off a piece of the bottom (making it shorter) and make a new port. It would be best to recalculate the port length for the new volume. (depends what woodworking tools you have available - easy enough to do with a router but you still would need to refinish the enclosure)
According to some remarks by Dave (Planet 10) the new FF125WK is eclipsing the previous 4.5" drivers (IF I understand correctly this includes the F120A and FX120)
coating FE127E aussiebuddha Full Range 12 12th November 2012 06:55 PM
Sub for fe127e SimZeSun Subwoofers 2 19th August 2011 09:38 PM
fostex fe127e MisterTwister Swap Meet 4 29th July 2011 01:18 PM
FE127E terminations? Scribble Full Range 4 17th October 2008 09:20 AM
working with the Fe127e Roemhild Full Range 17 20th May 2006 07:41 PM
Copyright 1999-2017 diyAudio
