Banned
I'm building my Frugel Horn MK3 and I'd like to have such a finish:
![]() I want to know what is the trick to have a finish like this I don't like frog but I'm looking for the trickLast edited by ARIYAHOOR; 17th June 2012 at 06:05 PM. |
#2 |
What, the flowers or the piano black?
The easy way is to use formica laminate. Real piano black? 1. black stain (optional) 2. pore filler if needed 3. sanding sealer 2 coats. Sand lightly with 320 no load paper 4. black lacquer, 2 coats. Sand very lightly with 400 no load or wet or dry (wet). 5. Clear lacquer, 6-10 coats. Level sand with 600 wet before the last coat. 6. Rub out with 800, 1000, 1200, 1500, 2000 paper, wet. 7. Buff with fine compound like 3M 'Perfect-It', follow with swirl remover and glazing compound. You thought it was going to be easy?? ![]() BTW, I gave the sandpaper grits in N. american CAMI sizes, not euro P grade |
#3 | |
Banned
I know Piano Black is neck-breaking job... is the speaker in above picture painted bare MDF or pre-laminated MDF?thanks again |
#4 |
I suspect that is formica or similar laminate, with the design already there. It could be wallpaper, or a faked computer render for that matter.
You won't get that look handpainting. I can see that it is a repeat pattern. You could start with wallpaper (or fabric) glued on, and then do steps 3 (maybe), 5, 6, and 7 from above. Always test on scrap... The frog is probably a color computer printout glued on after the black coats, and before the clear coats. Oh, BTW, with MDF you would start with a bunch of coats of opaque primer/sealer instead of sanding sealer. Last edited by Greg B; 17th June 2012 at 06:49 PM. |
| Paint old speakers? | illegalrugalah | Construction Tips | 7 | 7th June 2012 02:52 AM |
| mdf paint | joshuajoshua | Multi-Way | 16 | 8th September 2008 02:36 AM |
| Paint steel chassis with the "aluminum paint" used on wire fence? | vax9000 | Tubes / Valves | 2 | 23rd July 2006 01:14 AM |
| paint suggestion? | Dave Jones | Multi-Way | 5 | 21st May 2004 08:36 PM |
