Eeek! Pensil 10.2 Response Dips - diyAudio
Old 10th June 2012, 07:46 PM   #1
Default Eeek! Pensil 10.2 Response Dips
I finally was able to put a spectrum analyzer on my 3 Pensil 10.2 L-C-R speakers I built a while back. At one or two meters one of the three speakers is quite flat, but the other two have a pair of 15 DB dips at around 160 and 200 HZ, causing this whole 50HZ region to sag.
Could this be a stuffing / tuning issue? Any ideas?
Old 10th June 2012, 07:52 PM   #2
Frank Berry's Avatar
Were all three speaker systems in exactly the same location when you took the measurements?
Frank
Old 10th June 2012, 08:04 PM   #3
By the way, I think I tried the obvious things. Swapped drivers and the good and bad boxes stayed the same, so not a driver issue. Same placement, amp, etc for measurement so it almost has to be a box issue. One has the two dips as described and one has a single large dip from about 160 to 225 hz, or 10-15 db magnitude. The third, as I said, is marvelously flat, within a few db, through this whole range.
Old 10th June 2012, 08:09 PM   #4
frugal-phile(tm)
planet10's Avatar
Sounds like room issues to me.
Edit, later post saying same placement for measures rules out room.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th June 2012, 08:24 PM   #5
There must be a difference in the enclosures. It would have to be a big difference to have such an effect on the response.
Frank
Old 10th June 2012, 09:04 PM   #6
norman bates's Avatar
yup, there may be something going on in the box also, but room is probably the main problem.
Old 10th June 2012, 09:44 PM   #7
Bob Brines's Avatar
Ir sure looks like floor/ceiling bounce to me.
Bob
Old 10th June 2012, 10:17 PM   #8
Scottmoose's Avatar
Agreed, but if the cabinets have been measured in the same location, & the drivers have been interchanged to confirm it's not an issue with those (unlikely from what I gather about MA production tolerances), then I can only conclude there must be a box construction issue. Best guess is that either there's a problem with the damping, or there's a leak / leaks.
Old 10th June 2012, 11:00 PM   #9
frugal-phile(tm)
planet10's Avatar
Some impedance curves might be useful here.
dave
First build ever: Pensil 10.2 - in solid oak Swifty Markaudio 37 4th March 2012 03:52 AM
Ryan's Pensil 10.2 Build Log CabinetMakerRyan Markaudio 90 21st January 2012 11:33 AM
Pensil 10.2 build: Vent location? Swifty Markaudio 9 13th June 2011 06:01 PM
Illegitimate Son of Pensil - Alpair 10.2 buzzforb Full Range 135 25th April 2011 06:11 PM
Frugal-Horns Sachiko 8" horn speaker - Nasty dips in frequency response jmillerdoc Full Range 117 4th June 2010 04:23 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
