4ohm 6ohm 8ohm.... My home 4ohm 6ohm 8ohm.... My home - diyAudio
Old 9th June 2012, 06:39 PM   #1
Shido151 is offline Shido151
Default 4ohm 6ohm 8ohm.... My home
I've got an Onkyo Ht-Rc360 I love it except I cannot find where to adjust the ohm impedance, only thing about ohm in the manual is "not compatible with 4ohm speakers"
I just bought a Pioneer center channel that I didn't know was 6ohm until I got it.
The rest of my system is 8ohm, but my AV buddy said it's no big deal, moving on...
Here's the kicker, newegg has Martin Logan Motion 10 floor speakers on sale for $120 each, a solid $60 under the rest of the internet. I want them but they are kind of 4ohm..... I say kind of 4ohm because in the description they say "Compatible with 6 and 8 ohm systems" and so I don't know if they are compatible or not.
What the hell happened to ohm impedance? I used to know how it worked, you matched the speaker to the amp and nothing blew up, but apparently someone changed the rules.
So to the AV gods of knowledge I ask you, Can I keep the Center channel? Can I get the Logans or should I keep on shopping?
Old 15th June 2012, 02:54 PM   #2
marty70 is offline marty70
I have set up using Yamaha 6 ohm center and Martin Logan Motion 4 ohm and works with no problem. Now Onkyo ht rc360 will get hot no matter what and I did not see the fan running. Probably this built in fan is just for design or so.About the motion 10 be aware they are not very tall. Motion 12 will be better for front speakers if you find them or they have the new ones but not cheap. I would not worry to much. Good luck.
4ohm 6ohm 8ohm.... My homeHide this!Advertise here!
Edcor XSE (4ohm), GSXE (6ohm) wushuliu Swap Meet 1 14th February 2012 12:35 AM
4ohm drivers with 8ohm crossover? nonsuchpro Multi-Way 16 19th September 2011 07:14 PM
4ohm speakers for 8ohm application? SikSS Full Range 4 15th December 2007 04:09 PM
8ohm or 4ohm? adrrad Chip Amps 5 21st October 2007 04:29 PM
4ohm woofer and 8ohm tweeter. JoeBob Multi-Way 4 5th December 2001 01:45 AM
Copyright ©1999-2017 diyAudio
