WBAL Betsy-K 'small' ~40 Hz MLTL
Old 5th June 2012, 12:18 AM   #1
GM is offline GM  United States
GM's Avatar
Default WBAL Betsy-K 'small' ~40 Hz MLTL
'Parking' a design here, so I can link sims to this other forum thread:
Betsy K cabinet help? (Page 1) / FullRangeDriver Forum / Fullrangedriver Forum
Originally Posted by Greg B
For WAF, a TL or single fold TQWT can be disguised as a plant stand.
Originally Posted by KenR
I have space issues, I can only go 10 inch wide. about 15-20 inch deep and some 40 inches tall.
For a MLTL, etc., this driver wants to 'feel' at least a 4.4 ft^3 net Vb, so going back to the original max dims as overall, this equates to only ~2.5 ft^3 net.
Still, backed up against a wall, its relatively high F3 should work well if tuned to around 40 Hz and a heavy plant perched on top will sufficiently mass load the relatively skinny tower for a nice 'tight'/solid bass line once damped to 'taste' or even stuffed to semi-aperiodic if that's what sounds best.
Anyway, FWIW [15 deep/1st sim]:
L = 38.5"
w = 8.5"
D = 13.5"
driver centered at 5" down
3" dia. x 1.5" long vent centered at 30.8" down
All dims i.d. [inside] and approximate based on 3/4" [~19 mm] void free plywood or similar construction. Some ~1 dowels, vertically oriented 1x3 boards or plywood scrap tied together to form X braces at ~1/4 [9.625], 3/5ths [23.1] down from the top is sufficient bracing to keep the column from breathing if the potted plants are used, otherwise a full height riser tied to the center of the X bracing is required.
I recommend the top, one side and back be lined with 1" acoustic fiberglass insulation or similar, though sim is based on 0.25 lbs/ft^3 of polyfil [~10 oz] evenly distributed along its length.
Alternate [20 deep/2nd sim]:
L = 38.5"
w = 8.5"
D = 18.5"
4" dia. x 1.5" long vent centered at 30.8" down
GM
File Type: gif WBAL Betsy-K 40 Hz 'small' MLTL [alt].gif (6.7 KB, 336 views)
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 5th June 2012, 01:07 AM   #2
IG81 is offline IG81  Canada
IG81's Avatar
Sims look good, thanks for putting this up. Driven by low Z source I assume?
IG
Old 5th June 2012, 01:23 AM   #3
GM's Avatar
You're welcome! Yes, though should be OK with SET if away from the walls a bit and can be fine tuned with vent damping.
GM
Old 5th June 2012, 02:09 AM   #4
IG81's Avatar
GM
Only lately have I started to check out impedance from 0 to 8 ohm when simulating boxes; it's pretty enlightening to see how DF=1 can screw up a "warm" design. I also experienced it with the 49L/40Hz boxes I made for CG10T/AD9710, with a built-in 2-3dB hump on a low-Z drive, to battle baffle-step; it works well but did better on a low-Zout SS amp in my small room.
IG
WBAL Betsy-K 'small' ~40 Hz MLTLHide this!Advertise here!
Free WBAL Betsy 8" Fullrange Prototypes pjanda1 Swap Meet 5 15th July 2012 11:05 PM
Best Drivers for 40 - 170 Hz Sealed Box ? Oz_Audio Multi-Way 11 1st February 2007 06:36 PM
Most musical basshorn 40 to 100 Hz rick57 Subwoofers 5 18th November 2005 01:08 AM
Most musical basshorn 40 to 100 Hz rick57 Multi-Way 7 16th November 2005 01:36 AM
