baffle step compensation, zobel, notch filter - Page 2 - diyAudio
Old 3rd June 2012, 09:15 PM   #11
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
FYI:
The difference of using a 14 cm long port versus a 7 cm, both damped proportionally.
b
Old 3rd June 2012, 09:30 PM   #12
Originally Posted by bjorno View Post
FYI:
b
Your damping criteria is very obscure and hard to relate to practice.
Whatever number your playing with there seems no related practise.
I can't see the system the two cases are applicable to.
Lining a 70mm port with 6mm foam will reduce nominal diameter
to about 60mm and damp port modes. I can't see how you can
model this, I do it and it works well quite often. 1 cm foam in a
70mm port ~ detunes by half an octave, but can't be modeled
well as far as I know, its generally suck it and see, or measure.
rgds, sreten.
Old 3rd June 2012, 09:58 PM   #13
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by sreten View Post
reducing its length
increases the tuning frequency and is generally a very bad idea.
you say generally a bad idea ?
what is your reason for saying that ?
I have often found a shorter port to sound better
cant say the same about making it longer
but Im only talking about very smaller changes
putting foam in a port is way too unpredictatble
unless its hard foam
but sometimes light stuffing with acoustic material works well
but then its really not ported any longer
but actually I have had positive result with placing smaller pieces in some areas of the port
I have no idea what happens, but it works well, sometimes
Old 4th June 2012, 01:10 AM   #14
[QUOTE=sreten;3047122]Hi,
Obscure See*
What Port modes?. I see only quarter-wave modes related to the entire length of the airways where the port contribution is minimal.
model this,
It can easily be modeled by using suitable acoustical engineering
methods. The math can for example to be found here:
http://grputland.com/files/thes.pdf
I have access to the appropriate tools for this but showing these here is way above my commitment to help DIY:ers.
* Rather the opposite, I submitted all the numbers needed for an successful damped box/damped port design, here is more:
Select (dedicated for speaker use) a lump of modern ordinary fibrous damping material with the given weight of~ 1gram for a 7 cm long port.
Compress or tear the fibers apart in order to fill the entire volume of the port.
By doing so: This would correspond to a ~ density of ~0.2 kg/m^3.
Secure both sides by using an insect screen or similar.
The fiber tangle will stay and act as a flow resistance much like the 'Scan-Speak Flow Resistance Vent'.
The wider the Port diameter is compared to the port length, the better the linearity is expected to be for this arrangement.14 cm===> 7 cm is a good way to start with.
The airflow in the port is IMO/IME very small and already as a precondition, (pre-)filtered through the entire enclosure= a fill of denser stuffing in the box, thus only a near laminar flow is expected in the port.
Look at the magnitude of the port air velocity.
Considering this case(design): Your suggestion using port wall drag coefficients is IMO only a first step to consider if much higher port velocity exists and if the box were only lined at the walls for defeating internal reflexes.
b
serial filter baffle step compensation Marcelinho Multi-Way 2 17th May 2011 01:42 PM
Question about Zobel/Series notch filter silentwf Parts 5 28th November 2007 05:04 PM
Disadvantages of using Zobel and Series notch filter ? percy Tubes / Valves 3 24th June 2007 12:53 PM
zobel network and series notch filter djmann02 Multi-Way 1 9th January 2006 01:06 PM
xovers, impedence compensation, notch filters, baffle step, confusion? speekergeek Multi-Way 6 8th December 2003 04:46 AM
Copyright 1999-2017 diyAudio
