Tractrix Horn for 5" fullrange
Old 2nd June 2012, 09:28 PM   #1
ARIYAHOOR is offline ARIYAHOOR
Banned
Default Tractrix Horn for 5" fullrange
it's been awhile I'm barried in very nice-sounding Philips Ad-5061 5" fullranges... now I'm gonna build some Tractrix Horn for the unit. the plan is to build some 12" Onken bass bins with a Horn HF on the top
the Philips 5inchers are ~95db@1w/1m efficient, the question is: How much a proper horn will increase the overall sensitivity?
I use Tractrix Horn Auto Calculator xls attached
Old 3rd June 2012, 06:01 AM   #2
talaerts is offline talaerts  Belgium
Not an answer to your question, rather an aside: a few montgs ago I heard expensive AvantGarde horn speakers and learned that they use a 5" Widerange driver in their mid frequencies horn. These speakers were so good that I think you may be onto something...
Old 3rd June 2012, 06:42 AM   #3
Banned
you know what, all luxury big horn speakers can be build DIYed... Avantgarde, Oris, blah blah blah...
it is all about audio physic and money
the worst part is to build big round horns... I almost broke my neck to build a round horn but all attempts were experience of frustration
as you might know:
Horns are natural amplifiers
You could get same SPL of a big direct speaker by using a smaller diagram behind a horn with the same amplitude, with same wattage!
Horns increase directivity and this result in increasing total SPL with the same wattage
all these means:
Horns have a amplification factor (relevant to directivity and size, ect...) so every sound transducer will be more efficient by using in a horn instruction
all multi-hundred dollars compression drivers won't even generate 90db@1w/1m without Horn
you put a nice-sounding full-range speaker behind a well-designed horn and you get very high sensitivity
Old 3rd June 2012, 08:50 AM   #4
I must say that I have no idea how to elegantly build a nice round horn from scratch.
I also think that the available horns from Oris are rather expensive indeed, since (unless I am wrong) they consist of cast polyester.
Old 3rd June 2012, 09:05 AM   #5
Banned
round horns can be built using CNC cut MDF slices but endless of hours should be spent on sanding and sanding and some more sanding again...
the other method could be using paper! a nice pattern should be at hand which will shape the paper... I'm working on it
another way for me which was successful was to use PA horns! here there are nice aluminum public address horns, we had successful results to reshape them with some kind of hydrolic press machine so we could use them as Hi-fi grade horns but some parts ripped apart in reshape process so we should fill the gaps with filler and sand the final horn and paint them
Tractrix Horn for 5" fullrangeHide this!Advertise here!
Best 8" to 12" driver for 130hz tractrix horn 3GGG Multi-Way 279 7th September 2016 08:14 PM
Tractrix horn. DonB Full Range 2 9th May 2010 03:41 AM
Tractrix horn question lamia1 Multi-Way 5 16th February 2009 01:23 PM
Hemp 8" Coax and Tractrix horn? bambadoo Full Range 4 25th May 2007 06:13 AM
Tractrix horn AuroraB Multi-Way 12 8th September 2003 08:48 AM
