Running an A7.3 at full power
Old 10th June 2012, 05:20 PM   #51
Monte Verdi is offline Monte Verdi  United States
Monte Verdi's Avatar
Originally Posted by Bob Brines View Post
Using two drivers in the same frequency band is fraught with difficulties. The comb filtering will destroy the top end. I have not and will not consider doubling the A7's. This does not apply to the bass drivers because the wave lengths are substantially larger than the driver CTC dimension.
Also note that I am not trying to build a death metal speaker. Regardless of whether the A7's can do a continuous 95dB, and that combined with the output of the bass drivers should give at least 85dB 2m out. That's ear damage territory. If the A7's can actually produce 90dB 2m out, then there should be ~40dB dynamic range with an average home's noise floor.
The fact that the twin 8's ar more efficient than a single A7 is irrelevant as I consider bi-amping mandatory. The use of two 8's is produce a large surface area and therefore a sharper wave front on bass transients.
Bob
Bob,
I respect and understand your point here but as we both know " The math shows a bumble bee should not fly, but it does". I listen primarily too classical not Death Metal and in my naivete I must try it and hear for myself if I like it, or do I hear a phase/delay anomaly that is intolerable. Just trying to get choral and symphonic swings too manage better not constant ear splitting volumes. I will try it and let everyone know if it works for me!
Also, drivers are rolled off @ 12db starting at 100hz and subs entering at 120-140 Hz and go down to 25Hz.
Thanks, Ramon
Old 10th June 2012, 06:49 PM   #52
Octavia is offline Octavia  United States
Ramon please share your findings when you implement those other 7.3's. By the way what sub drivers are those?
Old 10th June 2012, 08:26 PM   #53
The subs are NHT Sub Two's with two 10 inch driveers and one 250 watt Carver/Sunfire
plate amp per cabinet. They also come with a separate cross over box that allows vol, phase, and freq adjustments in low, high and fixed frequencies. They have been extremely useful and sound quite good from 21-200 Hz.
Old 11th June 2012, 12:47 PM   #54
Rullknufs is offline Rullknufs  Sweden
Rullknufs's Avatar
Found a digital Radioshack SPL-meter for sale cheaply in Stockholm. Will take a few weeks for me to get it but when I do we'll see how loud I actually play with my EL70. It will be very interesting to find out
My audio and DIY blog: http://phimusic.blogspot.se/
Old 11th June 2012, 07:00 PM   #55
Rullknufs's Avatar
For an example, in this video clip I play my EL70eN very loud. They're crossed over at ~90Hz and at around 4:03 and forward you can see the excursion. Is that a safe volume level or am I pushing them too hard?
Old 11th June 2012, 07:08 PM   #56
chrisb is offline chrisb
don't be surprised if C weighted fast averages clock in not much above lower 90's -
kinda burnt out - taking a break
Old 13th June 2012, 04:28 PM   #57
Hope this is not off topic, but will a BIB/Alpair 7.3 single driver per cab manage decibel swings too 90 db 2.5 meters away in a moderately damped 13x21ft room? For classical not Throbbing Gristle!
Thanks,
Ramon
Old 13th June 2012, 08:20 PM   #58
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
Thanks,
Ramon
This, of course, is exactly my problem. I like to set my speakers in an 8' equilateral triangle, and that's pretty close to 2.5m. As a reference, yesterday I had Dvorak's 7&8 playing. I took out the SPL meter on my trusty iPhone and got just under 80dB for the forte's. Another 10dB is what I am looking for to handle transients.
The A10's will make this volume in spades, but we have already had that discussion. I suppose I will have to get a pair of A12p's once they are available.
Bob
Old 14th June 2012, 06:04 AM   #59
Swifty is offline Swifty  Netherlands
Bob
Hi Bob, did the alpair play full range? And playing louder than that caused, what? Audible distortion?
Old 14th June 2012, 12:26 PM   #60
fastbike1 is offline fastbike1  United States
I agree that this seems to be the critical question. Bob's scenario pretty much matches my typical listening w/ classical or jazz and I wouldn't consider it very demanding or unusual.
If the 7.3s can't handle this type of music/listening, what exactly is their expected "mission"?
Bob
I was so much older then, I'm younger than that now.
Running an A7.3 at full powerHide this!Advertise here!
Running the Scan-Speak 15w8530k00 full-range with no x-over chuck55 Full Range 27 14th September 2017 09:55 AM
power supply? running off a generator ArcticBreaze Instruments and Amps 8 13th March 2012 06:56 PM
Harm in running Pencil 7's full range? EvilYoda Full Range 2 7th July 2011 12:05 AM
Running full range (FR125) driver direct to amp...?? JRace Full Range 10 21st February 2006 08:41 PM
Running A Power Amp And A Receiver Big Kev ! Solid State 7 8th December 2004 05:01 AM
Copyright ©1999-2017 diyAudio
