Running an A7.3 at full power - Page 11 - diyAudio
Old 9th October 2012, 06:28 PM   #101
Octavia is offline Octavia  United States
Thanks ZMAN maybe it's not such a crazy idea after all. What crossover points and slopes did you use?
Old 9th October 2012, 07:09 PM   #102
zman01 is offline zman01  Bangladesh
Octavia,
XO was set at 110 Hz and 115 Hz if I recall correctly - both worked fine. Slopes I forgot as the ASIO plug-in setup in Foobar was done by forum member BanglaCX - the Alp 7.3 in Mar-Ken's were his. We also tried my Alp 12 metal, but sub integration was not as tight/clean. That's the problem with the Alp 7.3 - after you've listened to that driver, your other stuff starts sounding a bit problematic. BTW, the source was pretty non hi-fi for this experiment - a Creative 5.1 USB soundcard.
I do want to do the tapped horn's though... someday sometime when I get more time and some polyurethane glue.
BUT, what about tapped horns and usable BW? If I understand correctly, a TH will give you more efficiency, but not much BW? Is the SQ much better vs sealed or ported?
We are going slightly OT here, but would welcome some comments by the experts.
Old 10th October 2012, 02:06 AM   #103
It seems the point is that once the low end is taken off the Alp 7.3 they are really capable of significantly more output even if not quite up to symphonic crescendo levels (judging from what others have said). The band width for the Insubnia tapped horns is 25Hz - 125Hz and at least to my eye seems to offer a nice slender profile under a 7.3 monitor. Maybe that's just cobbling two unrelated set ups together but then again maybe together they'll make magic. All I can say for sure is when my budget permits I intend to find out.
Old 10th October 2012, 11:58 AM   #104
Bob Brines's Avatar
When you increase gain, you decrease band width. Tapped horns are usually designed to get usable SPL using a small driver as a sub. Works fine in that context. The discussion, however, is about FAST where the XO is going to be 200-300Hz. This is well out of the range for a TH, particularly when you consider that you need an octave or two overlap with the top.
Bob
Old 10th October 2012, 01:18 PM   #105
I didn't realize that FAST defined the XO as being 200-300Hz. I was considering simply relieving the 7.3 of having to cover the lower end below 120Hz. However you may be completely correct, perhaps the tapped horn approach won't be the best solution. I believe somewhere Nelson Pass made the comment that 160Hz seem to be the XO point he liked best. So....as they say, Back to the Drawing Board.
Old 10th October 2012, 05:35 PM   #106
Octavia,
FAST does not necessarily mean XO between 200-300 Hz. It can be lower if your FR unit can cope with your particular application (type of music/content, SPL). Subs will not go up to 300 Hz - so crossing with a mid-bass or "woofer" will only work here. And if I understand correctly, tapped horns subs with smaller drivers will not go up to 160 Hz - 110 Hz might be possible though.
Old 10th October 2012, 06:01 PM   #107
frugal-phile(tm)
planet10's Avatar
100-400ish is what i consider.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th October 2012, 07:58 PM   #108
Bob Brines's Avatar
Right. I start at 300Hz and then do what I need to to get a particular pair of drivers to play nice with each other.
(Unfortunately, we are running parallel threads on different forums. I assume you are also reading the Full Range forum. )
Bob
Running the Scan-Speak 15w8530k00 full-range with no x-over chuck55 Full Range 17 25th November 2013 08:27 AM
power supply? running off a generator ArcticBreaze Instruments and Amps 8 13th March 2012 06:56 PM
Harm in running Pencil 7's full range? EvilYoda Full Range 2 7th July 2011 12:05 AM
Running full range (FR125) driver direct to amp...?? JRace Full Range 10 21st February 2006 08:41 PM
Running A Power Amp And A Receiver Big Kev ! Solid State 7 8th December 2004 05:01 AM
Copyright 1999-2017 diyAudio
