Dallas II vs Kirishima - Page 9 - diyAudio
Old 19th April 2013, 09:40 PM   #81
zman01 is offline zman01  Bangladesh
Has Scott's Vulcan been mentioned?
Old 19th April 2013, 10:25 PM   #82
Send a message via Yahoo to stevodude
Arg.
that looks good too!
So I have a room (actually 2 rooms in one + a workshop) where I will use these.
the main theatre room is an L shape.
3mtrs x 10mtrs down the long L and 3.5 x 6 on the shorter L, 28mtr theatre screen at the end of the long, 3.2mtrs high ceilings
the workshop is 11M x 8M
Awaiting some fe206e's
Choices I see are:
Vulcan - double rear mouth horn - large room design - can't be too close to walls.
Kirishima - double mouth front vented Manafold (BVR?) - can operate closer to walls?
Dallas II - Single folded horn - more difficult angles.
Which would give the tightest bass, realistic accoustic and voice soundstage? (With the fe206e's I am awating)
Interested if all 3 of these have ever been together in one room :-)
S.
Old 20th April 2013, 04:22 AM   #83
S.
Maybe you will be the first one...
Old 20th April 2013, 09:01 AM   #84
Scottmoose's Avatar
Since Vulcan is a boundary-loaded design, I'm not sure where the idea that it can't be used near boundaries has come from.
'Realistic acoustic' and 'soundstage' unfortunately are entirely subjective terms and therefore depend on what the individual in question deems them to be, to say nothing of varying greatly depending on the system and room they are used in. The power-response of the three enclosures referred to is very different below ~500Hz given their terminus locations and horn designs.
'Tight bass' is also subjective, but largely indicates minimal group delay and a damped response, in which case my automatic recommendation would be dedicated woofers in a sealed box with a Qtc of 0.5 once amplifier output impedance et al have been factored in.
Old 20th April 2013, 09:31 AM   #85
Why did I know the answer would be subjective... :-)
I will build the dallas II , only because it's the hardest of the 3. :-)
Then I will think about a kirishima.
Sent from my XT925 using Tapatalk 2
Old 25th April 2013, 09:24 AM   #86
yyyrik is offline yyyrik  Russian Federation
Hello everyone. Do I need to put in Dallas II between the partitions ribs for strength?
Old 21st February 2014, 08:59 PM   #87
Trileru is offline Trileru  Romania
Hi guys, I'm half way through with my Dallas II project.
It's been like hell trying to put it all together. Cutting the parts is crazy, lots of freaky angles, and lots of stuff that can go wrong. After cutting all the parts I still need to correct some of them when gluing.
Anyway, I finished the exterior shell, and before I start putting the inside parts in I must decide for the cable route inside. Any ideas?
I was thinking of mounting the connectors on the upper back side. How should I run the wire? straight through all the inside panels or? Any ideas/pictures are welcomed!
Old 3rd August 2015, 04:05 PM   #88
So I finally got off my *** and decided to finish this project. It's been in the basement way too long.
I am now thinking on the route of the cable. What would be the best way?
The large parts inside are not glued in yet.
I was thinking of going straight through them. Make a hole in each and then glue it back. This way the cable is as short as possible.
Would that affect sound? The fact that there's the wire suspended in the middle?
Or would it be better (and harder) to glue the cable down to the wood and route it?
I need to glue the large piece in the back of the speaker and I need to make a decision.
I still need to check the tolerance of each part before I put the final panel. I have some pieces that are 1-2 mm shorter. And I'm not sure if the glue will cover that.
Old 6th August 2015, 02:54 PM   #89
Finally, I've finished one!
I decided to run the cable straight through the inside parts, then I filled the holes with glue. This way the distance is short and cables don't vibrate on the wood.
I also used metal inserts for speakers, so I can take them off without damaging the screw holes.
I still need to finish the other one and paint them but so far I really like the sound.
I used cat litter as filler. The speaker is heavy, I didn't expect it to be so heavy.
Old 6th August 2015, 06:05 PM   #90
Trileru,
It's a big cabinet and also has cat litter in the voids... the FE206En is a not a lightweight driver - heavy with a good sized magnet... so your speaker should be heavy.
The build is looking nice, and good luck with the remaining cabinet!
Fostex Dallas II maartentje Full Range 14 28th February 2017 07:23 AM
Dallas II plans Novacaine1968 Full Range 6 13th February 2010 12:42 PM
Dallas II + 208E = ? Mr.Mekulic Full Range 13 15th December 2008 05:20 PM
Where is the Dallas II amisdad Full Range 16 5th November 2005 04:57 PM
Copyright 1999-2017 diyAudio
