Dallas II vs Kirishima - Page 7 - diyAudio
Old 27th January 2013, 11:18 AM   #61
Trileru is offline Trileru  Romania
Originally Posted by planet10 View Post
OK, OK. Even thou its my birthday i did the last essential drawing... the attached plus that the interior widrg is 280mm.
dave
Coincidentally I worked last night until 3AM to retrace everything on my modeling software and everything checked out very good. Now all I need to do is recheck everything with your latest schematic but I recon everything will be ok. I managed to squeeze the whole project into a 2500x1250 mm board, so you can make one enclosure from one sheet. Monday I'll go get the wood and start the work. Thank you and happy birthay!
*later edit*
something like this picture. It's convenient if you buy the wood from some place that can only cut straight, then you can ask them to cut long pieces that you can fit in your vehicle. Then each piece can be sized into the corresponding parts. I left 1 cm between all parts so there's no problems if the initial cut isn't perfect. Units are in mm. The large sheet can be cut into 2 sheets of 450x1250 mm and 5 sheets of 280x1250mm. This way is easy to cary from the store and can be angle cut at home or somewhere else.
Old 27th January 2013, 01:20 PM   #62
OK, OK. Even thou its my birthday i did the last essential drawing... the attached plus that the interior width is 280mm.
dave
Happy birthday and thanks for this.
Old 27th January 2013, 02:16 PM   #63
Scottmoose's Avatar
A belated happy birthday (I don't entirely trust Skype to have sent the message earlier) Dave. That's a bit above & beyond on such a day.
Old 27th January 2013, 08:40 PM   #64
dave
Hi Dave, I hope you're having fun!
I rebuilt the speaker from your latest specs and I think there are 3 angles that don't fit right. First, the 45 degrees angle from the G piece should be 45.5 degrees, then F piece both angles should be 9.7 instead of 10.2 and 17.9 instead of 19. This way the H piece lines up parallel with the bottom part and almost all dimensions work out within 0.1mm from the schematic that you posted some time ago (the one with green writing, not the older one in red). Please correct me if I'm wrong thou. (after the party )
Old 27th January 2013, 09:35 PM   #65
frugal-phile(tm)
planet10's Avatar
Originally Posted by Trileru View Post
...and I think there are 3 angles that don't fit right
Thanx for the QC. The angles on the G & F pieces i was working on were correct, the pieces were not correctly drawn. I fixed that and redimensioned and they now concur with your numbers. I have replaced the image in the earlier post.
In actual practise tenths of a degree are impractical to work with, but we might as well be as true to Ron's work as we can.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th January 2013, 09:57 PM   #66
dave
You are right, hard to nail those angles when cutting/assembling. Thank you for your help, you made it easy for the rest of us to be confident in building this great enclosure!
Old 27th January 2013, 10:58 PM   #67
Happy belated birthday Dave!
I'm so ready for the saw now. I think the angles will be tricky to get exact but I will try. It will be some time before the finished product as I live in an apartment and my wife doesn't exactly like saw dust everywhere for days on end. I promise pics will come when they're glued up.
Old 28th January 2013, 09:36 AM   #68
zman01 is offline zman01  Bangladesh
Belated best wishes and Happy Birthday Dave!
Old 29th January 2013, 07:24 PM   #69
squalor is offline squalor  United States
squalor's Avatar
It's nice to see there's still intrest in the Dallas II design. It's been a long time since I built my pair but they still sound great and pass the WAF test.
I wanted to address a few questions asked in this thread.
Cutting the top off the design ? I did this to a lesser extent; I split the baffle just above the driver and tilted it back 18* , You may notice in this pic that Dave hosts on his site of my build. Ron Clarke commented negatively to my decision. He said the baffle size was a calculated part of the design. My change would raise the stage. Also, the larger baffle may help smooth the upper frequency response of the FE206E, which is a bit ragged and spikey.
Using the 206eN ? This Fostex model did not exist when Ron designed the Dallas II but the FE208 sigma did. Ron said the sigma could be used by adding a 3/4" thick section to the back of the compression chamber, reducing it's volume.
Old 30th January 2013, 02:17 AM   #70
Wait a second....there isn't data for the new FE206's?
Dave the thumbs here inrecent posts, are they downloadable somewhere?
Fostex Dallas II maartentje Full Range 14 28th February 2017 07:23 AM
Dallas II plans Novacaine1968 Full Range 6 13th February 2010 12:42 PM
Dallas II + 208E = ? Mr.Mekulic Full Range 13 15th December 2008 05:20 PM
Where is the Dallas II amisdad Full Range 16 5th November 2005 04:57 PM
Copyright 1999-2017 diyAudio
