#41 |
frugal-phile(tm)
been done for sometime.
And i have a big lead on getting Dallas into Sketchup, given the vector drawing i took a snapshot of ... email meif you want that. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#42 |
I'm looking forward to the final design on this. It may lend itself to a "hybrid" lamination on my CNC machine for two of the corners that are most visible externally.
For example, the two tight curves -- cut as stacked pieces -- won't take much more material than the three panels that must be cut to form the bends. I would probably cut the "bends" out of some 1 inch MDF I have and the flat panels out of 3/4" plywood. |
#43 | |
#44 |
What happened to the Dallas II plans..?
Ervin |
#45 |
frugal-phile(tm)
#46 |
Hi diyaudio and everybody in diyaudio
My name is Kha(Le Mai Kha)I'm come from Viet Nam.My favourist is hear the sound of spearker and power of amply,but in Viet Nam,we don't have much chance(if buy one speaker is too expenssive and it not too good to hear).and now,I want to assk you,is anyone can help me.I want buy 4 lower speaker of JBL about 30mm just the secondhand.anh 2 horn of Electro_voice and I want make a speaker like JBL 6600.please help me.please contact me with mail is le.mai.kha@gmail.com.thanks for all help.and this speaker I will use in my house |
#47 |
I know this is an old thread, but what really is the difference between the Dallas 2 and the Kirishima?
Assume the same driver fe206en. what is the difference in sound? different bass? Thanks!
It is not you... you are it. |
#48 |
frugal-phile(tm)
Bigger horn should give a bit more effortless bass. As well Dallas II was designed for the older FE206.
But either one are very good. dave
#49 |
I decided to finish the Dallas II project so I began redrawing from the bits that were left online. I had access to a computer with SolidWorks software so I began drawing each piece and then assemble them together. I only encountered two minor problems and it may be that it was late and I was tired. I finished the 3D model and have each piece modeled separately but they are in the solidworks format. I could export them to dxg I think, have to search a bit for that thou. I attached some pictures with the problem areas but I think that could be very easily fixed. I may try the next week to correct. If interest is shown I could export all individual parts in dxf and archive them.
#50 |
Forgot to mention that if you have all the pieces cut perfectly than you just connect one to the other, you don't need any reference points but the middle inside piece. That has to be constructed with some dimensions into account. If someone could tell me the reference points and dimensions I'd appreciate. To illustrate what I mean I attached a comparison picture to show how the center arrangement can move. I had no reference for it in my modeling software so I set it by eye when I took the screenshot.
Also there's one piece that I can't see how to easily manufacture, it's the turning edge on the lower pass. It's round and thick. I may make that from a 18mm thick piece and round it by sanding or some other means. I also made a rough arrangement of all the parts included for one speaker and it seems that they would all fit into a 2500x1250mm plywood sheet with minimum loses. |
| Fostex Dallas II | maartentje | Full Range | 5 | 25th April 2010 01:18 PM |
| Dallas II plans | Novacaine1968 | Full Range | 6 | 13th February 2010 12:42 PM |
| Dallas II + 208E = ? | Mr.Mekulic | Full Range | 13 | 15th December 2008 05:20 PM |
| Where is the Dallas II | amisdad | Full Range | 16 | 5th November 2005 04:57 PM |
