Old 23rd May 2012, 09:38 PM   #21
castorG is offline castorG  Italy
So it would be a good thing to take off the back too Dave?
What about the base? I think it would be better to let it as it is, fitting it with sand, adding this way some weight.
Ervin
Old 23rd May 2012, 09:40 PM   #22
Ah, last question (for tonight, since here it is 23:38):
What about giving to the lateral pannels of the mouth a C form? I see that it can be found in other Ron's cabinets.
Old 23rd May 2012, 10:16 PM   #23
i think those 'C' forms are part of the end flare shaping that Ron uses in his horns? i think i read he was responsible for the C shape on the Frugal too.
Old 23rd May 2012, 10:19 PM   #24
frugal-phile(tm)
planet10's Avatar
Something like this -- i'd be temped to lose the greyed back corner too. If you are going to curve the mouth i'd extend the bottom.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd May 2012, 10:28 PM   #25
Still up studying here..
How much would you extend it Dave? Since I don't know anything about horn design, what would a C formed mouth to the sound (stage)?
Do you have, or Scottmoose, a spl responce of the dallas II?
Old 24th May 2012, 01:06 AM   #26
Never been able to make 'hornresp' work..
Gafhenderson, could you make a similar spl response for the fe206en into the dallaII? Of course only if it does not take too much time to do so, otherwise don't consider my question.
Ervin
i've given up on the Dallas II as the plans are truly awful to read and most the angles listed on it aren't actually accurate, so you'd be doing a lot of fine sanding. i'd be happy to plug it into hornresp if you can get a reasonable overview of the horn path for me. i started making a 3d model of it and got annoyed and frustrated with the plans, so turned my attention to kirishima as its plans are very well presented.
Old 24th May 2012, 01:21 AM   #27
frugal-phile(tm)
planet10's Avatar
Windows ate all the original CAD plans leaving only a random collection of raster pdfs -- it has been successfully built from those a number of times. At some point someone will step up and redraw them... i redid Austin A126 (but it took a big push ($$) by another member)
dave
Old 24th May 2012, 02:28 AM   #28
dave
i was intending to actually redo them once i'd deciphered them. I was fairly annoyed by various other things that haven't gone right today, so i decided to relax by doing something that was easier to follow.
the kirishima's really aren't as big as you'd think are they? although i am using 3m(10ft) ceilings in that. I did a render of them for people to see. the AN8's are in that box but i'm not sure they'd work very well. still a bit grainy as i only let them render briefly.
i'll turn my attentions to the Dallas 2's and see if my patience can keep up.
Old 24th May 2012, 03:30 AM   #29
next to 6ft ish man
Old 24th May 2012, 03:33 AM   #30
frugal-phile(tm)
planet10's Avatar
The footprint is not that big.
Stuffed back into a corner like that, you'd likely need to find a way to throttle back the bass.
dave
Fostex Dallas II maartentje Full Range 5 25th April 2010 01:18 PM
Dallas II plans Novacaine1968 Full Range 6 13th February 2010 12:42 PM
Dallas II + 208E = ? Mr.Mekulic Full Range 13 15th December 2008 05:20 PM
Where is the Dallas II amisdad Full Range 16 5th November 2005 04:57 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
