Dallas II vs Kirishima
Old 23rd May 2012, 07:04 PM   #11
castorG is offline castorG  Italy
Don't you think it would affect the sound?
Old 23rd May 2012, 07:04 PM   #12
chrisb is offline chrisb
Originally Posted by sippy View Post
Just a thought...........
Think of a ring of wood, multiples stacked to make a cylinder, to cut this using cnc / laser is wasteful........
Divide each ring into segments, glue the segments so the joints at say 45deg to each other, from curves to strait sections can be formed as 'J' sections, the majority of the straits can then be cut on a table saw. Yes its slightly more complex to make / glue up a horn enclosure in this manner.
Thinking about it a little more, one could have just the curved sections cnc/laser'd and flat material joined in to make the strait sections........BIG saving in cost there.
start doing the math on the programming, machining and assembly time for the tight nesting required for high yield on any curved shape, and most particularly horns such as these, and you quickly gain appreciation for rubberply / Kerfore and vacuum bagging
no matter how you do it - CCM
like my mind, this space intentionally blank
Old 23rd May 2012, 07:08 PM   #13
not detrimentally so, compared to the diffraction effects at edges of front baffles cabinet
Old 23rd May 2012, 07:26 PM   #14
gafhenderson is offline gafhenderson  United Kingdom
does this look approximate to kirishima's tuning/performance?
its got a AN super 8 neo in this sim. if this is approx, i'll put the numbers into the MJK worksheet.
Old 23rd May 2012, 07:39 PM   #15
Never been able to make 'hornresp' work..
Gafhenderson, could you make a similar spl response for the fe206en into the dallaII? Of course only if it does not take too much time to do so, otherwise don't consider my question.
Ervin
Old 23rd May 2012, 09:04 PM   #16
sippy is offline sippy  United Kingdom
start doing the math on the programming, machining and assembly time for the tight nesting required for high yield on any curved shape, and most particularly horns such as these, and you quickly gain appreciation for rubberply / Kerfore and vacuum bagging no matter how you do it - CCM
true enough Chrisb, the other way, if cost is 'no object' would be to buy veneer and bag over forms, a friend and i did this a few years ago to make a small run of custom skateboard decks, though in the end it turned out easier to make them with an ultra high density foam core, Pu at 240kg m/3, skinned in glass/carbon.
On my 'to do' list is a pair of 'bookshelf' speakers for my bedroom using this foam, though I've got to get the Emken out the way first
Old 23rd May 2012, 09:04 PM   #17
the link didnt post
http://www.homeblown.co.uk/HD/
Old 23rd May 2012, 09:15 PM   #18
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by chrisb View Post
Very pretty - in fact it already has been done with the Austin:
That is actually a variation on Dallas II. I'm pretty sure that Ron had little or no input into that one, unlike the Austin 166 that layertone did.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd May 2012, 09:21 PM   #19
frugal-phile(tm)
planet10's Avatar
Originally Posted by gafhenderson View Post
all i know is that it's a laser, and it needs to be special treated wood that is suitable for use with lasers.
I talked with a fellow that had access to that CNC techto do FH flat-paks and we decided that the materials limitation made it impractical to proceed.
dave
Old 23rd May 2012, 09:24 PM   #20
frugal-phile(tm)
planet10's Avatar
Chrisb, what do you think abouy simply taking off the head of the dallas II? I guess it want be detrimental from a sound point of view, since the dallas III does the same thing.
I would do that as a matter of course -- removing all of the redundant voids. Taking the big chunk off the front should decrease the diffraction signature.
dave
Dallas II vs KirishimaHide this!Advertise here!
Fostex Dallas II maartentje Full Range 17 12th November 2017 07:53 PM
Dallas II plans Novacaine1968 Full Range 6 13th February 2010 12:42 PM
Dallas II + 208E = ? Mr.Mekulic Full Range 13 15th December 2008 05:20 PM
Where is the Dallas II amisdad Full Range 16 5th November 2005 04:57 PM
