will the fe168 fit in the fe163 en box
#2 |
Probably. What special advantages are you hoping to obtain?
#3 |
If the discussion is on the FE168 SigmaES I'd be interested, owning a pair and not finding any suitable cab, other than a BIB. Thanks.
Sam |
#4 |
Fostex's factory design isn't too bad. http://www.fostexinternational.com/d...ez_enclrev.pdf
I can't speak for anyone else's cabinets, but it should also go in Haruna with a bit of juggling of the damping; although that cabinet wasn't designed for the ESigma, it has size on its side. Last edited by Scottmoose; 20th May 2012 at 07:51 PM. |
#5 |
scott.
i have my fe168 ez in tom zuow. blh and its time for a change. was considering fostex desg. then i saw fe163 en. just wondering if it would work. thank you |
#6 |
frugal-phile(tm)
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
Forgot about that. Probably the best option so far.
#8 |
Thanks for the info.
Can we expect anything better coming?
Sam |
#9 | |
define "better" - application / room constraints (if any) can be a major factor in enclosure design
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
| Fullrange in 2-way....? | teddytusen | Full Range | 10 | 31st December 2010 09:59 AM |
| 8" and smaller fullrange vs 12" and up fullrange in OB | c3conv | Full Range | 11 | 24th August 2010 05:59 AM |
| mostly fullrange | tomtt | Full Range | 1 | 25th April 2006 12:04 PM |
| Fullrange for me? | bjackson | Full Range | 13 | 31st August 2005 09:55 PM |
| fullrange or 2.5 way?? | AudioGeek | Full Range | 2 | 18th August 2004 07:26 PM |
